really high fuel pressure?
Old Apr 2, 2009 | 06:22 PM
zz4IROC's Avatar
Car: 1988 iroc
Engine: 350 forged crank, pistons, 11.5:1
Transmission: t-5
Axle/Gears: 10 bolt 3.73
I have an 88 iroc with 24lb injectors, crane AFPR, and not sure about fuel pump. SHOULD be stock. I put a fuel pressure gauge on it and cant get any adjustment whether the screw is all the way in or out. I also get my one and only reading of 66lb with the engine off. Everyone says to adjust with engine running bu the needle jumps sparatically between 65-70 lbs. With just the ignition on i get 66 lbs. PLEASE HELP ASAP!!! Joe.
Old Apr 4, 2009 | 01:38 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: really high fuel pressure?
They are right, you need to adjust fuel pressure while running. Are you sure your gauge is reading right? Either the gauge isn't reading right or the AFPR is not working correctly. 65-70 PSI isn't a bad thing, but stock pressure is about 44 lbs if memory serves, so that much pressure will surely make the engine run rich. Remember to test with the vaccum line removed from the AFPR and plugged.
Old May 20, 2010 | 09:26 PM
conlinj's Avatar
I know this post is really old, but did you ever get your car fixed? My buddy is having the exact same problem. Even went back to the stock hat and its 62psi
Old May 22, 2010 | 10:56 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
pretty sure the highest it should get is about 50ish. id have to look it up on alldata. its been a while for me.
Old May 22, 2010 | 11:58 AM
conlinj's Avatar
I figure its a clogged return line since everything else is new.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
