Racing Fuel
Old Apr 3, 2009 | 07:56 AM
GTA BANDIT's Avatar
Car: 1991 Trans Am Gta
Engine: 350 Tpi
Racing Fuel
i have a 1991 trans am gta 350 tpi. i am going to the drag strip today and was wondering if i should run racing fuel in it or just run 93 octane with octane booster? also for just regular driving should i be using 87,89, or 93?
Old Apr 3, 2009 | 08:29 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Racing Fuel
You do not need the extra octane of racing fuel or octane boosters since you don't have super high compression or power adders. With your engine, to stay away from knock & pinging, I would fill up with 93 for the track and daily driving.
Old Apr 4, 2009 | 01:33 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: Racing Fuel
Higher octane fuel than the engine needs to stay out of knock will actually hurt power and milage. Higher octane fuel is harder to ignite and burns slower, that's how it resists autoignition. You shouldn't need more than 93 octane, and even 91 is probably fine. New high performance cars are running over 11:1 compression and making 500HP on 91 octane pump gas.
92camaroJoe
Jul 29, 2023 07:57 PM
italiano67
Dec 11, 2016 09:21 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
