87 TPI IAC Replacment..
Old Apr 6, 2009 | 03:34 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
The book says the measurment should not exceed 1 1/8 when replacing a new IAC.Does that mean you have to adjust the pintle up to 1 1/8,or any measurement before that is okay to install???
Old Apr 6, 2009 | 08:38 PM
bowtie1983ss's Avatar
Engine: 5.7 Liter Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: 2.77:1 Borg Warner (Stock)
Re: 87 TPI IAC Replacment..
The 1-1/8" is the distance from the gasket mounting surface of the IAC valve to the tip of the pintle. Basically, the pintle can't be sticking out of the IAC Motor more than that or it'll damage the seat or IAC when you screw it into the housing. Depending on your IAC, you either screw the pintle in by turning it (by hand) clockwise (into the body of the IAC). or you push it in with firm hand pressure to obtain the 1-1/8" or less measurement. Torque the IAC motor to 13 lb ft when you install it into the housing. No adjustment is needed after that, the computer will adjust it from there.
Old Apr 7, 2009 | 02:13 PM
bgmoss's Avatar
Car: 1986 TA t-tops
My book says to carefully rock it back and forth while pushing to avoid damaging the worm gear. That's the only way I could get mine to retract(89).
Regards
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
