My roc don't roll
Old Apr 8, 2009 | 03:35 PM
irocnroll1987's Avatar
My roc don't roll
I bought my 1987 iroc in june, of 86 it has 55k on it know. its all stock, no add on's at all. I'm having trouble with it running. the right side ( pass side) injectors are not firing all the time. i'll be on the freeway and the car is running like the day i bought it.. then it starts spitting and miss firing with black smoke out the back, if i swerve back and forth like a nascar before a restart it will some time's clear up and i can continue on my way. ive noticed the fuel pump sounds loud. ive changed the fuel filter, and checked for water in the system, that all looks fine. someone said it may be the computer, but others have told me that would cause it to shut off all the fuel injection not just one side.. im lost someone PLEASE help me..
Old Apr 12, 2009 | 06:40 PM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
Re: My roc don't roll
black smokes is caused from burning oil...did you over fill the oil?
thats all i got.
bump.
Old Apr 12, 2009 | 10:15 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
If it comes back to life when you swerve I would start looking for bad wires/connections. Also kinda agree with above^^^check oil....or better yet how many quarts did you put in it in the event the dip stick is messed up.
Old Apr 12, 2009 | 11:09 PM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
thats all i got.
bump.
Thought blue smoke was oil and black was fuel?
Old Apr 13, 2009 | 09:40 AM
speedfreak91's Avatar
Car: 1991 trans am gta
Engine: 0.060 over L98 speed-o-motive 5.7
Transmission: madd dog 700r4 w/ 34-3800 stall
your right. black is fuel, white / blue is oil.
Vintageracer
Jan 10, 2020 05:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
neekolzun
Aug 24, 2015 04:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
