Any ideas for more cheap power
Old May 1, 2009 | 03:20 PM
  #51
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Any ideas for more cheap power
Of course you can put headers on without pulling the engine.
Old May 1, 2009 | 09:31 PM
  #52
balistic's Avatar
upgrading the exhaust is the best bang for the buck, by far and fairly simple to do in a good weekend with hand tools. Vigilante has proven significantly faster E.T's and 0-60 times but aren't the cheapest part, especially if you don't need a new converter. As far as cheap, near free, DIY setups does anyone have some proven tricks to help this poster, me and anyone else......such as adding resistors to sensors , removing/rerouting things, inexpensive swap-this -part-for -a -newer model type tricks, or the such???
Old May 2, 2009 | 12:43 PM
  #53
89RsPower!'s Avatar
Look for "free mods"
Old May 2, 2009 | 06:46 PM
  #54
balistic's Avatar
yeah, I found a bunch on the homepage late lastnite kinda hidden if you haven't been told where to look, been taking notes, and setting up a plan to try a few things,
Old May 5, 2009 | 10:08 PM
  #55
90BlackGTA's Avatar
Car: 1990 Trans Am GTA
Axle/Gears: 3.42's
Originally Posted by QuickStyle
Ya you will gain at least 20hp by using higher octane gas, but only if you have vtech. k enough sarcasm.
actually using higher octane gas will make it harder to burn all the gas, using the lowest octane gas without getting detonation will give you the most power/efficiency. the reason for having higher octane gas it to prevent detonation with high compression engines, a lot of people have the misconception that higher octane gas gives you power because race cars use it.
Some of the f-body's especially the GTA's like myself with the 5.7 litre REQUIRE 91 octane as a standard...so I wouldn't just use regular gas...best to check your owners manual first
Old May 6, 2009 | 05:10 PM
  #56
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
1. Make sure car is in tune and running the way it should.
2. Gut air boxes (A cold air kit is a HUGE waste of money on a 3rd gen camaro)
3. Read the stickies at the stickies at the top of this page (WAY too many replies in here referring to getting a bigger throttle body)
4. Enjoy driving your car and SAVE your money. There is no point dumping money into bolt on mods when the problem is your 700R4 peanut cam combo.
I wasted a bunch of money on a bunch of mods for my 305 (Mine is an 85', so I do not have the peanut cam) over the years, by far the best mod I did was swaping to a T5. A manual can make even a slug like my 2.2L s10 fun to drive. If you can do it yourself, a T5 swap can cost less than a ridiculous throttle body (after you sell your working 700r4 to somebody that blew theirs up)
Old May 6, 2009 | 06:45 PM
  #57
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Well said SmurfN'!
Old May 7, 2009 | 04:37 PM
  #58
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
The T5 trans is better than the 700R4 then i seen plenty of those for around $200
evilstuie
Apr 14, 2016 08:52 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
mustangman65_79
Aug 7, 2015 09:55 PM
