Throttle body hose connection question. Doesnt make sense!!
Old Apr 10, 2009 | 12:10 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
Axle/Gears: 3.42 Posi Disc
Hi All,
I cant figure this out and need your help. On the side of the throttle body on TPI cars there are two hose fittings. According to my emmisions sticker on the hood. The top (1/2" nipple) goes to the crankcase ventilation (3/8 fitting) on pass. side valve cover. The bottom (3/8" nipple) goes to the charcoal canister purge. Well if you look at the design of the throttle bodies and see how they route the vacuum threw them it doesnt make sense to me.
The top 1/2" goes over top the throttle body to a small port that only will pull vacuum when the throttle body opens. Wouldnt this stop or restrict the constant flow of vaccuum to circulate the PCV sytem? The bottom 3/8" pulls vaccuum constanly. It doesnt seem proper. Should it not be the other way around? Is my sticker messed up on my hood?
Please help me out! Confused in KY
kyrenegade
Old Apr 10, 2009 | 07:20 PM
Damon's Avatar
Re: Throttle body hose connection question. Doesnt make sense!!
The hose that goes from the TB to the valve cover is the FEED side of the PCV system. Fresh air is drawn from the TB INTO the pass. side valve cover through that hose, circulates through the motor picking up blow-by gasses and is then drawn OUT the other valve cover, through the PCV valve and into the intake manifold to be burned with the rest of the air/fuel mix. So that TB hose doesn't get vacuum- it's a fresh air feed that picks up air IN FRONT OF the throttle plates, where little or no vacuum exists under any amount of throttle opening.
Old Apr 11, 2009 | 07:54 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
Thanks for the reply! I guess what has thrown me was the size of the nipple coming out of the side of the throttle body on the top. Its a 1/2 inch compared to where it feeds into the valve cover 3/8". Wonder why they made these two different sizes?
Thanks Again,
kyrenegade
Old Jul 2, 2025 | 04:54 PM
henny156's Avatar
Interesting, so does the ball check valve work in the reverse direction on the right side of the engine?
C10TPI
Jun 18, 2019 01:13 PM
95 4x4
Sep 6, 2009 04:44 PM
gscz28
Feb 18, 2008 02:08 PM
Black_Widdow
Sep 22, 2005 06:22 PM
david roush
May 3, 2003 01:17 AM
