bad egr symptoms
Old Apr 10, 2009 | 06:26 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
bad egr symptoms
Can a bad egr cause my car to run lean, burn raw fuel and also burn fuel twice as much as normal? let me know if it can and what other symptoms it can also give you?
Old Apr 10, 2009 | 09:19 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: bad egr symptoms
You question is one of contradictions :-) An EGR that is leaking or stuck open could make it run lean and idle poorly. But it won't cause it to burn twice as much fuel. I'd look at your injectors. See if the pressure drops quickly when you turn the key off.
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
