Just got the rockers installed
Car: ws6
Engine: ls1
Transmission: m6
I am now planning to go to the dyno with my new 1.6 full roller rockers installed. When I do I will come back to this thread and post the results. I was wondering what to expect. They are advertised as 15 hp to the motor. So does around 7wrh sound accurate? I also have one more question. If I decide to get a zz4 or zz9 cam will I be able to use the 1.6 rr or will the stock 1.5's be needed? Thanks in advance
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Just got the rockers installed
you should be able to use the 1.6rr but check the piston to valve clearence is always a good idea........did you dyno before putting on the new rollers.....cause air temp..mileage....and other varibles might not be the same as the factory numbers......
Car: ws6
Engine: ls1
Transmission: m6
Yeah I had it dynoed last year.
Engine: L98 494hp
okay...good deal....what are the cam specs for the ones you thinking about it..... need duration, lobe seperation, and lift...
Car: ws6
Engine: ls1
Transmission: m6
Oh I am not at that point yet. I probably wont get a cam for about a year or so. I was just courious what to expect at the dyno. Thanks though.
ambainb
Apr 25, 2016 09:21 PM
IrocZ'85
Aug 17, 2015 06:24 PM
