lunati opinions
Old Apr 12, 2009 | 11:40 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
Transmission: 700 R4
lunati opinions
hey guys ive been looking at lunatis sledge hammer 383 roller assembly and the voodoo hydrolic flat cam lifter pushrod timing pack not sure which heads i wanna run yet im just wondering how well there parts handle abuse is not a race motor its for a fun car it will see the track and it will see some street abuse please let me know wat u guys think
Old Apr 13, 2009 | 08:44 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: lunati opinions
It's more than enough for a street engine. Personally I'd run a 6" rod. For a 383 that will make 450-650HP I like a 4340 crank, 4340 H-beam rods with capscrews, and flat top pistons with two valve reliefs. A flat top piston in a 383 with a 70cc head will be right around 10.5:1 compression depending on deck height and gasket thickness. I really like Mahle pistons. I used a set in my last 383 and will use them in the next one. They are coated and come with rings. Overall though Lunati has a great rep and I wouldn't hesitate to use their products.
I would ditch the flat tappet and run a roller cam if the budget allows. I rollerize the whole valvetrain. It reduces friction, which improvespower and reduces the heat thrown off into the oil. It also allows for more aggressive ramps, which translate into more low and mid lift power. Area under the curve is the key to a street engine, and that's where a roller cam shines.
Old Apr 13, 2009 | 04:17 PM
Toms88GTA's Avatar
Car: 88 GTA
Engine: L98 350 TPI
Re: lunati opinions
the 383 kit i was looking at is al 4340 forged h beam rods flat top pistons it says with 64cc head wil be around 11.1 and i would love to run a roller set up i may but it all depends on the budget thank u for the imput once i do the build ill put up pics and specs
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
