87 5.0 TPI idle high
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Does anyone know why the idle will stick more on a high idle when the temp outside is colder,verses when it's warmer?? It doesn't much when it's warmer..But still idles like **** till motor is warmed up near temp. Temp sensor??? Thanks
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: 87 5.0 TPI idle high
An intake vacuum leak that seals when the heat makes the metals expand? A bad IAC motor?
Car: 1985 Z28
Axle/Gears: garbage 2.73
Your question is kind of misleading. Sounds like youre asking whys the idle stay fast longer on cold days than on warm days. Thats simple.....it was designed that way. Now if you think you may have a problem....it could be a few different things. Coolnat temp sensor, depending on the year it could be a crappy cold start valve, or on later models the cold start fuel enrichment protocol could be jacked.
Iroc8t8
Aug 26, 2015 08:14 AM
Sanjay
Aug 12, 2015 03:41 PM
