No gas getting to engine
Old Apr 18, 2009 | 03:01 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Transmission: TH-700R4
Axle/Gears: 2.77
ok well the title says it all... the fuel pump turns on; we got pressure at the fuel rail but nothings getting to the engine. you can even hear the build of pressure. the fuel pump turns and theres so much pressure it sounds like its being over worked. the injectors aren't opening up and the have 12 volt power. Is there hose that needs to be checked? wires?
Old Apr 18, 2009 | 03:20 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: No gas getting to engine
There is a rubber hose between the tank lines and the steel lines on the car that could be kinked or swelled shut, filter could be totally plugged (unlikely), metal line could be kinked, or rubber lines from steel lines to the engine could be kinked or swelled shut, or worse the connection from the actual fuel pump to the sending unit could be swelled shut or even blown. Hope this helps.
Old Apr 18, 2009 | 04:33 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
That would not make me happy.
Old Apr 19, 2009 | 12:53 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
yeah i checked it all, and its all good fuel is getting to the rails. there is enough pressure but no gas. we also checked for saprk with the timing light and theres no spark ether.
Old Apr 19, 2009 | 01:04 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Your not getting spark or fuel from the injectors . Sounds like you may have a bad ignition module .
Old Apr 20, 2009 | 08:58 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
How do you know you arent getting gas out of the injectors? Did you flow test them?
Old Apr 25, 2009 | 01:36 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
yeah i took out the ignition module and got it tested at a shop and it was good.
I found a disconnected ground and put it with coil ground. {Is that a good ground?}
Does anybody know where all the grounds are?
i need to check them all.
I think I'm not getting gas because after a few times of cranking, i pulled out a spark plug and smelled the tip for gas and i didn't smell anything.
I only have until Wednesday to work on my car to work. so any help is appreciated!
Old Apr 25, 2009 | 02:14 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
This may sound stupid but have you tryed pulling the timeing connection to see if it would get spark and fuel and fire up ?
Old Apr 25, 2009 | 03:24 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
Originally Posted by 89-bird
This may sound stupid but have you tried pulling the timing connection to see if it would get spark and fuel and fire up ?
yes sir, there is spark but its sooooo low i hardly felt it ( i used my finger to check for fire )
I'm pretty sure not all of the grounds are on, id really like to know if someone could help with the ground issue. i check how many volts i was getting in the fuse box and i should be get 12 but i have 4.
Old Apr 25, 2009 | 05:33 PM
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
HA HAA!! I Think i found it.... loose wire in the steering column, it says security when trying to start up.
Old Apr 26, 2009 | 07:53 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Yeah that would be for VATS system . That didn't even cross my mind .
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
