heat soak issue and wont refire until completely cool
Car: 1987 Z28
Engine: LG4
Hi all, after much work all the ign system has been replaced thinking it was a coil or distributor.....still wont refire after hot drive. Then let it cool for 4 hours it refires like it should. If you crank the car it acts like has no fuel or spark and wont start at all. I have a fuel pressure gauge hooked up and it shows 45 psi all the time wether hot or cold so i want to say vapor lock or boiling fuel is not a issue.....how can i check the injectors to see if the injectors are getting heat soak?...without pulling the intake apart
Car: 89 T/A , 78 T/A
Engine: 406 TPI , 455
Transmission: 700R4 , 4spd
Axle/Gears: 3.08 , 3.73
Re: heat soak issue and wont refire until completely cool
have you replaced the ign. module? i've seen several cars that when they were hot the ign. module would stop working until they cooled down. also if there wasn't enough grease under the module.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Pull the injector connectors and using an ohmeter check each injector. You should be in the 14-16 ohm range. Doing it with the engine hot is the best way but if you're problem is being caused by the injectors, you'll notice the problem with them cold.
Car: 1987 Z28
Engine: LG4
im running used LT1 injectors and according to LT1 owners stock 24#'s ohm at 11-13 ohms....mine all test from 12.3-12.5 last time i checked
like i staed before also....EVERYTHING ign related has been replaced
--ign module
--pick up coil
--cap/rotor/wires/plugs
--ign coil
i have hedman longtubes and the are clost to the lines on the driverside but im still reading the same FUEL PSI cold OR hot
im wondering if the injectors are heating up and shorting out and causing the other intectors not to fire. If you drive car for 5-10 minutes car will refire...but drive for 20-30 minutes or beat on car it wont refire for 3-4 HOURS!!!!!!!!!
im really close to just torching the car....evil car
--ign module
--pick up coil
--ign coil
Car: 1987 Z28
Engine: LG4
okay, my dad got a set of ford injectors that have the plastic body from his work....cough cough ford lol.
They are bosch, but i can find ANY info on them....i know they require the adapter from EV1 to the EV4(like ls1)
Car: 1987 Z28
Engine: LG4
okay im about to burn this car down lol......went and drove car...well beat the **** out of it so it would get nice and warm. Pulled in garage and let sit for 15 minutes. Turned key and wouldnt fire up at all.....NOTHING!
so i grabbed my handy multi-tester and ohm'd out every injector only to find exactly the same ohm rating as when the injectors are cold! WTF??????
im lost...i even tried unplugging the MAP sensor...didnt do anything different(try to make car rich)
i tried unplugging the coolant plugs(heard about computer glitch and being too lean on hot start...didnt do anything.....
ok...ive got spark and 45psi of fuel pressure......im 99% sure its got to be fuel injector death or computer is being ghey
ALSO, when car does run and drive it is retardly slow and has no power at all......im talking mid 15 seond 1/4 times slow aka embaressed to own slow
im not sure if knock sensor is pulling timing or what....this damn car is slow as *****
short mod list:
327 bored to 333ci(zero decked block)
forged flat top pistons(-5.3cc dome)
pink rods
1103 summit cam(214/224 .442/.465 at 112LSA
stock 083 iron heads
stock tpi intake setup
3300 stall...big but motor loved it BEFORE TPI
700r4...with shift kit
3.23 gear set
im wondering ig the 350 knock sensor in my 327 is acting up and with 10.1:1 compression its pulling timing...it feels dead all though the power band.
short mod list:
pink rods
3.23 gear set
Car: 92 GTA/ 00 TA
Engine: 383/350
Had a crazy issue with my dad's GN last year. Very similar symptoms as bad injectors. Turns out a new battery fixed the issue. Apparently it had a cracked plate internally.
Car: 1987 Z28
Engine: LG4
the car has a new battery
i have replaced everything BUT map sensor and fuel injectors
thats only things i cant find in the pile of receipts
Car: 1987 Z28
Engine: LG4
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I had the exact same problem once with my car......and it turned out to be fuel pump. Same thing though....I checked it with pressure gauge and it said 40+ psi, so I thought that couldn't be it but what happened is it was vapor locking...getting air in line...next time it does it....try bleeding fuel line at schrader valve...see if air bubbles in fuel line.....
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Car: 1987 Z28
Engine: LG4
oh and heads up......it has brand new pump....i have thought vapor lock also might be issue
im saving up for a ls swap.......im tired of this garbage...ive spent so much money trying to get this car just to be reliable
Engine: L98 494hp
Yeah...I've notice a lot of thirdgens with fuel related problems....
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
does it crank at all, or crank real slow. On my car the starter would get so hot it would not crank at all untill it cooled off.
I have the same problem with my 89 formula if i find anything out i tell u i have also replaced the same things you have. Do u have a rough idle to?
Car: 1987 Z28
Engine: LG4
okay...this one might put you guys in a tail spin mentally lol
i drove car to friends house and sure enough 15 minutes go by and crank...crank...crank...NOTHING!
it turns over the same as cold...
i hook my laptop up and while i crank car the injector pulse from the computer isnt doing jack crap....
so buddy comes up with an idea.....unhook battery cable and reset the comuputer....at first it didnt work so i unhooked it for 6 minutes
i also heard about hard starting hot with tpi cars so before i hooked the battery up i disconnected the CTS on the front of the intake. I hooked the battery back up and VROOM! the retarded car fried up and just like it does cold.
So people that have hard or no start hot like heat soak unhook the battery and the CTS for 6 minutes or more....then hook back up and should fire up....
Car: 92 GTA/ 00 TA
Engine: 383/350
That's exactly what my dad's GN did with the battery "trick". Do you have a different one that you could swap in? Even new batteries could be bad......
Didn't try the CTS thing though.
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Have you tried to replace the CTS that may be the whole problem . It is probably sending a bad signal to the computer .
Car: 1987 Z28
Engine: LG4
Car: 1987 Z28
Engine: LG4
im so close on just giving up on this thing......one thing to try is the 3 wire o2 sensor trick and maybe the whole 1 wire and long tube issue is killing my car and running stupid lean like ive heard here on TGO
Car: 1987 Z28
Engine: LG4
okay after install of 3 wire bosch i learned car is running rich.....very rich
like 11.4 at WOT rich lol
a friend came over and added some spark advance and tried figuring out the hot start issue only to be dumbfounded like me lol.
i am seriously lost about why it wont refire hot....unplug teh CTS and 9 out of 10 times it will refire. My friend added fuel in the hot start table(coolant temp vs injector pulse width) and didnt help
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Which of the three CTS's are you unpluging you have one for the fan/s , one for the gauge , and one for the computer ?
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
subscribing for info--I used to fight hot start problems alot back in the day.
Car: 1987 Z28
Engine: LG4
this in turn tricks computer into thinking the motor is cold and thus enriching the fuel ratio. It doesnt work everytime but it helps out.
im going to have to swap injectors it seems.....ohm'd them out and they spec out to 12.3-12.8 and are LT1 spec but i suspect they arent firing correctly hot.
motor is running great and actually rich under WOT.....like 11.6 rich LOL
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Yeah I would try stock injectors for your engine and see how that does you may be getting to much fuel to your engine with those LT1 injectors to cause the rich WOT .
Car: 1987 Z28
Engine: LG4
so i need to plan accordingly......whats 22lbs good to hp wise?
www.southbayfuelinjectors.com
Car: 1987 Z28
Engine: LG4
just posted a sale on design lll and 24lb fms injectors....10% with discount code: TG11
looks like buying a set of 24lbs
Car: 1987 Z28
Engine: LG4
just did a noid test on the injectors and when its hot and wont refire.....it has injector pulse so it HAS TO BE the injectors!
im waiting on southbayinjectors to say wether the III's or FMS injectors are better buy
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
From the link the only thing I can see is they both run a 4 pattern spray . The Bosch lll may be a 22 lb instead of a 24 lb . And the 24 lb injectors are cheaper .
Car: 1987 Z28
Engine: LG4
oh well.....live and learn everyday
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
what computer is in that car adn what tune are you running? Has it been tuned for that 327?
If not thats the problem. Hard Hot restart is because your getting too much fuel on startup. Coolant temps are up, and startup enrichment is spraying too much fuel. this happend to me on my 383 and i was running stock startup tables.
Leaned it out and its firing hot everytime easily.
I would think you just need to tune that car abit more
Car: 1987 Z28
Engine: LG4
it has been tuned for the 5.3L and 24# injectors. Thing is the car isnt spraying fuel when hot and will fire on carb cleaner for a sec and die out due to no fuel. Its weird due to o2 sensor under WOT is showing rich condition and 14.73 under light cruise. BUT, test them with 12 volts when they sit and soak heat for 15 or more minute with car shut off.....they dont fire. When the car is running they click pretty good.
Car: 89 Iroc-z
Transmission: TH400
YOu have a wideband in it correct? because a stock style nb, even a heated 3 wire setup wont show air fuel ratios correctly at WOT
Car: 1987 Z28
Engine: LG4
i dont have a wideband yet but im stuck on what one to get. Im looking at inovative products basic digital one. AEM and such are really pricey and have a lot of things i dont need.
i couldnt really do any good pulls today due to semi slick roads. Seems to run better and now the idle is better. Found out the HVAC/cruise vacuum line wasnt sealing on the plenum nipple and was a vacuum leak lol. So i capped it off until further notice and runs and idles better lol.
only thing that sucks is finding a place to mount the wideband o2 sensor.....i have longtube headers and im "borrowing" from a fiend. lol figure that out.
the car is sluggish when the gas is stomped and under partial load it drives better(more advance from computer...wtf?)
partial throttle = 35 degrees
WOT before = 29.9 degrees
WOT now 31* degrees
i want to jack the timing up to 34-35 degress. Due to me having 9.9:1 compression and decent cam i have been running sunoco 94 ultra and car seems to run better on this than lower grades
i need to have friend tune it a lot more.......
WOT now 31* degrees
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I hope you get it man and sorry to hear you didn't see the discount code .
Car: 1987 Z28
Engine: LG4
im still waiting for the injectors but heres what she sounds like after fixing a few issues so far......and yes i need valve seals
http://www.youtube.com/watch?v=A1CFWbAfqak
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
We'll see how things shake out this weekend, but like we discussed, I'll throw more timing at it if you like. Or you can drop a chip off, I'll burn it, and you can pick it up. I'll either add more timing in the base map, or I can put more in the PE spark table. I just wanted to be cautious because burning a new tune is free, buying new pistons is not.
Also, we gotta get this hot start issue fixed so you can drive the car.
To whoever suggested pulling hot start injector pulsewidth.... I know exactly what you are talking about. My 383 did the same thing, and when you opened the throttle up it would finally start. So I leaned it out and its perfect now. Shelby's car won't even try to fire no matter what you do and it does not smell rich while trying to start. I know it doesnt make sense, but it really seems like it's just not getting fuel on a hot start....
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 86 IROC
Engine: 383
He has has MAT sensor out beside his air filter. I'll pull up his .bin and see whats up....
Car: 1987 Z28
Engine: LG4
Car: 1987 Z28
Engine: LG4
okay....after a few beatings....the car SEEMS to be fixed!(knocks on wood)
Jeremy(1MeanZ) did some crazy tuning to my chip and added a bunch of fuel to the hot start table and now it fires right up hot!
He also did some other tuning stuff.......car is running good!
now im not sure what intake to buy......im going T5 swap soon also
i HATE automatics
i HATE automatics
Car: 86 IROC
Engine: 383
Car: 1987 Z28
Engine: LG4
Car: 1987 Z28
Engine: LG4
well....id figured id let people know whats gone on last few days.
UPDATE!
after being mad at car for so long a friend conviced me to work on the car and i tore the intake all apart down to the lower base nothing left lol. I replaced all the tpi gaskets and used rtv to help seal them this time. I also put the SouthBay Fuel injectors in(24# Ford racing ones).
Let the rtv dry and fired the car up...HOLY Y*(UH the cars intake sounds like a pissed off vacuum cleaner
So i know i had a stupid bad leak lol. It idled right down to 500rpm and now the iac is showing itself to be bad(sticks). The runs like a bat out of hell now but i have murdered the poor 700r4's 2nd gear
ONLY bad thing now theh tune is screwed up now due to car is ruuning right and is uber rich on restarts and having to press petal to the floor to fire is annoying lol. BUT IT FIRES EVERY DAMN TIME NOW!!!!!!!!!!!!!!!!!!!!!!!
NOW its time to figure out what to do about a trans lol.....im thinking t56 due to the lt1 sitting on my garage floor i just bought for 300 bux muahahahaha
UPDATE!
Terrell351
Jun 13, 2021 01:13 PM
