87 TPI 5.0 thermostat
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Will the factory computer/chip work with a cooler thermostat?? 160/180 Or does it have to be the recommended 195.I believe..
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: 87 TPI 5.0 thermostat
It will work fine with the cooler T-stat but to get the fans to come on earlier will require a chip reburn or a manual fan switch.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
A cooler than OE t-stat will simply open sooner. If what your after is to reduce the normal operational temps, along with the cooler t-stat you'll need to replace the OE fan switch with an aftermarket fan switch.
There are a lot of posts on this topic. Try a search for more detailed info.
Iroc8t8
Aug 26, 2015 08:14 AM
Sanjay
Aug 12, 2015 03:41 PM
