temp fuel solution?
Car: 1991 z28
temp fuel solution?
Im going to be putting a largely ported TPI set up on my L98 in a few weeks, and I'm wondering what I should do about fuel for the short term. Can I get away with just getting 24# injectors and an AFPR and bumping up fuel pressure or am I not going to be able to drive the car until I get all the programing gear and change my ecm for the injectors?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: temp fuel solution?
are you just adding the ported intake setup....no cam or heads??? You should be able to get away with stock, but 24# should be a good match...I would run stock fuel pressure with those, you shouldn't need re programming with just an intake....or even a gear swap.....I used a stock computer with 24# injectors on a l98 with a .465/.460 crane cam, and some aluminum heads, headers, and gears, and it ran great...I would say your okay.
ambainb
Apr 25, 2016 09:21 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
