1985 Camaro Z28 TPI running rich
Old Apr 30, 2009 | 10:21 PM
jwdrouyor's Avatar
Car: 1985 Chevrolet Camaro Z28
Engine: 8 Cylinders 5.0L FI
Transmission: Automatic
I Found a Z28 and bought it for real cheap. i have receipts for a engine and transmission rebuild in 2002.
work i have done:
fuel filter
alternator
battery
full tune-up
new ECM
problems:
it runs rich so bad that i could choke myself without having the garage door down.
it also has been hard to start sometimes if the cars sits for a while but if i start the car and then shut it off and then start it within the next 10 min or so it will start right up... i put some fuel injector cleaner in my tank and now it seems to be fine now but its been to early to tell.
I pulled my plugs and found them to have oil on them. and the look old even though there only six months old with little driving distance.
my oil pressure dash indicator has always went all the way up. i figured there's something just wrong with the sensor.
if anyone could help me i would greatly appreciate it.
Old Apr 30, 2009 | 11:11 PM
king1960's Avatar
Re: 1985 Camaro Z28 TPI running rich
Unplug the cold start switch on the intake manifold, se if that helps
Old Apr 30, 2009 | 11:18 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
It wouldnt hurt to change the o2 sensor. That can cause a fat condition.
Old May 1, 2009 | 12:58 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
fuel pressure regulator, check for fuel in the vacuum lines (usually strong smell of fuel) typical fuel pressure regulator symptoms, Hard cold starts, easy warm starts, running pig rich. only other culprit i can think of is leaky injectors, thankfully if you do the FPR you can check for that at the same time
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
squiggy2
Aug 9, 2015 09:30 PM
