Please help! Oil pressure switch
Old May 2, 2009 | 02:12 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I got my block back from the machine shop. They gave me a block that was already done (same casting number) instead of my exact block.
Now my oil pressure switch won't thread-in. I think the threads are different in the hole? Is there another spot I can relocate the sensor to? If not, can I just plug the hole and not use the oil pressure switch?
I did a search and found out the switch is used as a backup for the fuel pump relay.
Please advise! Thanks!!!
Old May 2, 2009 | 05:40 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Please help! Oil pressure switch
AFAIK, the hole on the top of the block for the oil pressure sending switch has been 1/8" NPT (pipe thread) forever.
Put the eyeball on it. There still might be a broken piece of sending unit or pipe in there.
Old May 2, 2009 | 06:52 PM
Thanks for the response paulo57509!
I will check it out.
Old May 2, 2009 | 07:02 PM
91RedRagtop's Avatar
Car: 1991 Firebird Convertible Horsepow
Engine: 406 w/Motown 220 heads
Transmission: 5 speed manual
And you don't want to not use it. Unless you don't care what your oil pressure is running!!!!!!!!!!!!
Old May 3, 2009 | 08:26 AM
S10Wildside's Avatar
Go to the local auto parts store and ask them to pull an oil pressure sensor (it's actually a switch/sender and not a sensor) for the early 90s S10 4.3L engine (VIN Z). They should be able to locate the oil sending unit using 1/8" NPT. This will thread to the back of the block behind the intake manifold, and will be compatible with your gauge. If given the option for "light" or "gauge", tell them "gauge". Same harness connector, same wiring configuration.
I think these are the part numbers:
ACDelco D1824
GM 25036941
Standard PS236
Airtex 1S6592
Notice the 1/8" NPT thread.
The switch portion of the "sensor" is just a redundant power source to the fuel pump. GM did away with this for the LT1 f-body and just about every vehicle I'm aware of after 2000.
The oil pressure switch is NOT going to stop the fuel pump from running if there is no oil pressure. This is a common misconception.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
