What o2 sensor for Edelbrock Headers?
Old May 5, 2009 | 04:01 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hey all,
I have Edelbrock headers on my 305 tpi.. they are pretty old as they are completely brown. Not sure about the oxygen sensor tho but I want to replace it just in case now that I'm starting to tune...
I bought a single wire o2 sensor already for like 25 bucks but I fear that I may need the 3 wire heated one.. It's located on the driver side header, so I don't think it's too downstream..
Is the single wire good enough for the ECM to get an accurate read on these headers??
Thanks!
-Marc
Old May 5, 2009 | 04:23 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: What o2 sensor for Edelbrock Headers?
I use a Bosch 3 wire for '92-'93 LT1 vettes (p/n 13077) and have had never had any troubles. I don't see any real trouble running a 1 wire unit but from what I've read in the past a heated unit gives more accurate readings. How true that is I really don't know but I can say I can tell a difference in the way mine runs with the 3 wire versus the 1 wire.
Old May 5, 2009 | 04:38 PM
Yeah I got the bosch 1 wire for my 305 tpi... I heard they are good for making oxygen sensors... I'd like to have the best reading possible but if it won't make any difference between the 1 or 3 wire with my edelbrock headers then i won't waste the 80$...
Thnx!
-marc
Old May 6, 2009 | 10:50 AM
anyone else run edelbrock's headers on here? What type of o2 sensor are you using?
Old May 6, 2009 | 04:25 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I used a one wire with no problem. I have since converted to a heated one but found no real differance.
Old May 6, 2009 | 05:25 PM
Hmm so I think I'll install the Bosch 1 wire o2 sensor that i already bought... Thanks all!
92projectcamaro
Jan 18, 2016 08:00 AM
red rock
Sep 4, 2015 03:42 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
