87 5.0 TPI high idle at idle/cruise
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
The throttle sticks during cruising,and idling.(off and on) If i tap the gas pedal it comes down..Any clues?? I've changed the TB gasket,the intake runner gaskets,cleaned out the TB as best as i could,egr gasket,and checked for vaccum leaks....Still didn't help..
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Re: 87 5.0 TPI high idle at idle/cruise
Yea it sucks! Pisses me off.I also had changed the thermostat,and temp sensor.Want to try change 02 sensor,if i can get loose.If you find out anything.Let me know please.
Car: 88 camaro convert z28
Transmission: auto
I have had the same problems and i have justed changed the O2 and throttle position sensors and it has made a huge differance especially when i changed the tps.
I hope this is some help.
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Cool,thanks for info..The IAC on mine was new last year..I put a TB off a 350 on last n.It seemed to be better,but only time will tell.Maybe my TPS is bad..
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
