TPI problem
Old May 12, 2009 | 03:24 PM
daatv's Avatar
Engine: 350 -5.7 l
Transmission: 5 speed
TPI problem
I have a 1988 trans am with a 350 tpi mostly stock
In the morning when i go to work my car idles a little high around 500 rpm to high and in the afternoon it well go around 1000 rpm to high i have to tap the gas to get to come down and sometimes as im driveing i have the cruse control on but i dont i took it to a friends shop so he could put it on a scanner
to see if the was any codes the was nothing he sudgested to try some typ of carb cleaner to see if the is any vacume leaks i tryed this and still cant find anything HELP
Old May 12, 2009 | 05:27 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: TPI problem
Pull your computer down from the pass. side of the dash, pull the aluminum case off it and flex the PC board around while the car is idling high.
If the idle comes down while you're flexing it, it's the computer. Just get a reman. from the dealer...
Very common problem with all the TPI cars...
Old May 16, 2009 | 05:51 PM
3rdGenFreak1227's Avatar
Car: 86 IROC Z
Engine: LQ4
Axle/Gears: 4th gen 10 bolt 4:10
Re: TPI problem
DO NOT touch the computer while idling or when there is power going through it....if its not bad...the static charge from your body will fry it...those things only operate on about 5v in most places and static electricity just from your body will put out way more than that...the only way to truly condemn a PCM is to go down through a list of diagnosis and eliminate everything else...but again don't just grab it and flex it...you will fry it...
Old May 16, 2009 | 07:29 PM
daatv's Avatar
Engine: 350 -5.7 l
Re: TPI problem
no i found a better way than grabing it Monday im putting on a friends scanner
Old May 16, 2009 | 09:55 PM
Car: 86 IROC Z
Engine: LQ4
Re: TPI problem
good...thats a way better course of action lol
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
