Accell runners in/Now no Run at all
Old May 21, 2009 | 08:27 PM
1970 Buick's Avatar
Car: 1989 GTA
So I spent the better part of my free time this week installing my new big bore runners. What a pain in the A$$! If I had known what it was going to take to get these things in I would have paid someone else alot of money to do it. Well, I start it up tonight and it starts to stall out unless I rev it up to around 2500-3000. I also hear a good amount of air being sucked in. I assume this is caused by a vacuum leak. I can't get the thing to run long enough to spary TB cleaner to see where the leak is. Well, after a couple starts, it won't start at all now. Turns over but doesn't catch. Anyone else have any ideas or suggestions? I have searched around already too..to no avail
Old May 22, 2009 | 04:58 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Accell runners in/Now no Run at all
Get a good light and look at the install, there is a chance that the tubes are on the wrong side or that the cold start hole is not plugged.
I would look for a big vacuum leak.
Old May 22, 2009 | 08:05 AM
1970 Buick's Avatar
Car: 1989 GTA
I put the runner with the cold start injector on the driver's side. These runners came with a block off for the cold start injector. Also, I just noticed that the plug under the plenum, in the back, that is like a pigtail connector is undone. Could that be causing any problems?
Old May 22, 2009 | 08:22 AM
Damon's Avatar
Probably not, but you should fix it anyway. That's the MAT sensor (Manifold Air Temp).
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
mdtoren
Aug 23, 2015 12:52 PM
marcusaw
Aug 10, 2015 08:13 AM
