TPI-HSR, making funny sound from intake
Old May 22, 2009 | 04:23 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Hi, I have a 383, with AFR heads, HSR, and 42lbs injectors. I finally after a year, got around to getting the car started, and now i notice sound, its a clanking sound, its like two sounds per second and comes from the intake and not the heads. Clank, one million, clank... I dont really know what it is, and and when I rev it up I dont really hear, nor notice hear an increase in the incidents of the sound. I have read on one of the searches that I did, that maybe the noise could be coming from the larger injectors, and the aftermarket fuel pressure regulator. Any insight will be of help.. thanks Randall
Old May 23, 2009 | 03:04 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: TPI-HSR, making funny sound from intake
Ttt
Old May 23, 2009 | 05:04 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
did you start it last year, if not maybe you dropped a bolt in intake
Old May 23, 2009 | 09:39 PM
fastsspr's Avatar
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
Take a vacuum hose of about 3 feet long and use it has an stethoscope to pin point the noise. With that you probably find easier where the noise come from.
You did a test run to the car?
Just my .02 cents
Old May 23, 2009 | 11:20 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
U recently changed the heads to some AFR. And I know I didn't drop any bolts. The sound appeared after the head swap. I think it might be my valve lash but it's not comming from the heads so that's why i'm lost.
Old May 29, 2009 | 12:00 AM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
also i need to add that the noise started after i had my tranny worked on, the new clutch installed.. thanks
Frozer!!!
Jan 19, 2024 04:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyle5647
Aug 15, 2015 11:56 PM
mustangman65_79
Aug 8, 2015 12:07 PM
