i hate this car
Old May 31, 2009 | 07:45 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
i hate this car
got a 91 z 5.0 tpi ,new ford 30 injectors,intake gasket,fuel pump,tps,coolant temp sensor,new plugs,new distributor,no cat. car has a surging idle,and bucks under light acceleration and on cruise,if so one knows the problem let me know it will set code 45 on the highway.
Old May 31, 2009 | 09:17 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
Re: i hate this car
Did you get a new chip burned to compensate for the 11 pound increase for the injectors? (I think 305's had 19lb injectors), or check your TPS voltage (.54v), maybe even something simple like a vacuum leak
Old Jun 1, 2009 | 04:16 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: i hate this car
I have 30# injectors on my 6.4Liter and their more than enough for my application.
Why did you use them on a 5Liter and as asked did you update the programming?
Old Jun 1, 2009 | 09:53 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Re: i hate this car
dude, too heavy on the injectors
go back to the stock 19s unless you have a blower or somthing
Old Jun 1, 2009 | 09:58 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: i hate this car
I think the Ford injectors are rated @ a higher PSI, so they aren't actually flowing 30lbs/hr. But, I would think there is still a big difference in flow between the stock 19's and whatever the Fords are flowing. Just like everyone else has been asking: Did you get a chip programmed to account for the new injector flow rate?
Old Jun 1, 2009 | 10:14 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: i hate this car
Holy crap,IIRC Lingenfelter ran a 400hp 355 with 19lb injectors. 30lb in a 305 is way over kill.. code 45 is running rich at the 02 sensor
Old Jun 1, 2009 | 10:49 PM
driver101's Avatar
Re: i hate this car
car ran the same with stock injecotrs except no code but then again it never ran well/long.if i could figure out why on take off and at cruise this thing jerks around like it did before i changed everything i might enjoy this car and not want to part it if you dive it like you stole it this 5.0 is impressive but if you try to drive normal it acts like you don't know how to drive a stick.as far as tuning i threw a hypertech chip in and it was no differerent
Old Jun 2, 2009 | 12:04 AM
BlueIroc-Z's Avatar
Re: i hate this car
You would need a custom chip, one that is specifically programmed for the new injector flow rate. AFAIK Hypertech just changes fan turn on temp (so you can run a lower t. stat) and maybe some slightly different timing...
Old Jun 2, 2009 | 12:47 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: i hate this car
wow, stock 305 injectors are 19lb, and ford injectors actually flow more than specified, like getting ford 19lb injectors is like getting 22lb bosch injectors. anyways i know your over fueling it. also check your TPS sensor, that usually makes the car act wierd while driving
Old Jun 2, 2009 | 03:22 AM
BlueIroc-Z's Avatar
Re: i hate this car
Yeah, I was wondering if I got it backwards... Thanks for the clarification.
Old Jun 2, 2009 | 01:09 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: i hate this car
i got him the injectors, they are 24lb
Old Jun 2, 2009 | 10:51 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Re: i hate this car
they would still need a custom chip though
Old Jun 2, 2009 | 10:57 PM
benny42's Avatar
Car: 1986 Corvette
Axle/Gears: 3.07
Re: i hate this car
I probably bucks at low speed from too much base timing.
What is it set at? benny
Old Jun 3, 2009 | 01:15 AM
Car: 1979 Malibu
Engine: Blown LSx
Re: i hate this car
6 Degree's
Old Jun 3, 2009 | 07:38 PM
benny42's Avatar
Car: 1986 Corvette
Axle/Gears: 3.07
Re: i hate this car
Ok, it isn't the timing. I hope you get it sorted out. benny
Old Jun 6, 2009 | 11:59 PM
net_coma's Avatar
Re: i hate this car
You replaced the TPS. That is the only thing stated that has a variable. When you work on something and it does not work after, go back to the last thing you worked on. Recal the TPS.
Old Jun 7, 2009 | 07:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: i hate this car
I was finally able to eliminate my surge by removing a lot of timing and a lot of fuel through programming.
24lb over 19lb injectors is too much for the ecm to compensate for. The ECM can only handle 10% not 20% without reprogramming.
Old Jun 7, 2009 | 11:08 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: i hate this car
Back off the fuel pressure at the regulator
Old Jun 7, 2009 | 02:57 PM
driver101's Avatar
Re: i hate this car
replace injectors with 19lbs that seems to cured all problems except i think i may have a crappy plug wire as i have a slight surge part throttle so new wires and this car should be ready to go to a new home
BlueIroc-Z
Jun 9, 2019 03:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
midias
Aug 22, 2015 01:42 AM
Linson
Aug 21, 2015 02:12 PM
MY87LT
Aug 17, 2015 08:43 AM
