Bad clattering Knock!!!
Old Jun 7, 2009 | 06:00 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
My intake manifold was leaking. I replaced the gaskets, put new 23lb injectors, coil,cap, rotor and valve covers on. I started the engine and it has a bad clattering knocking sound that is consistent with acceleration. I thought it was the valve covers? Put the oem back on and still have the knock. Im praying its not a bearing or a valve. Any help would be greatly appreciated!!! My car is an 89 Iroc with a 5.7 tpi
Old Jun 7, 2009 | 07:28 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Bad clattering Knock!!!
Did antifreeze get into the oil?
Old Jun 7, 2009 | 07:36 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
No, the oil is very clean. When I put the oem covers back on I just set them on with a couple bolts to keep oil from going everywhere. I did not put the gaskets on though. Im hoping without the gaskets the covers are sitting low but the sound is still coming mainly from the passenger side. Tomorrow Im going to put the gaskets on to see if that works. I wish I could run it without the cover but the thing was shooting streams of oil out. I didnt think it shot oil out like that? If it needs a new engine I will probably part it out as it needs body work and a paint job.
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
gta892000
Sep 16, 2015 12:40 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
