TPI wont start Need help!!!
Old Jun 9, 2009 | 11:23 PM
Andersons89gta's Avatar
Car: 1989 Trans Am GTA
Engine: Swapped to L98
Transmission: 200r4
Axle/Gears: Stock 3.27
Car somtimes starts fine and runs fine but if i shut it off car wont start back up for at least an hour or so. i did spray gas into the throttle body and it fired right and ran fine no problems but after i just it off it just wont start up again. I have just rebuilt the motor and transmisson did the same thing before too. NEED HELP PLEASE!!!! confused as hell
Old Jun 10, 2009 | 10:03 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: TPI wont start Need help!!!
Well if you can spray starter fluid in it and it will start than that would indicate to me a fuel delivery problem. Ide start by checking out the fuel pressure.
Old Jun 11, 2009 | 12:31 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Sounds like a classic case of a bad starter solenoid. Go get yourself a new starter. They are about 40 bucks. When the starter gets hot after driving for awhile it becomes heat soaked and if the solenoid is bad it will not let the car start again until it cools back down or may even work intermittently when the car it hot. Very common.
Old Jun 11, 2009 | 06:08 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
if it cranks over but does not start its not the starter solenoid. The solenoid only engages the starter. The OP said it fires up on starter fluid, so how can you say its the solenoid. If you have multec injectors ohm check them, I bet you have a shorted one. They should read 16ohms. If any are below 10 thats your problem.
Old Jun 11, 2009 | 08:45 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Also check the fuel pump relay for the 2 sec at key on, if the relay is bad then you are running off the oil pressure switch. When cold oil pressure at cranking speeds is high enough to engage the fuel pump, when hot it is not. When you spray then when the motor fires the oil pressure rises and all is well again.
This is a backup system and the main (FP relay) is likely bad.
Old Jun 14, 2009 | 04:10 AM
burnout88's Avatar
Car: 88 IROC
He did not state whether it cranks or not. Just that it won't start. He needs to clarify. As I mentioned the soliends can be intermittent. Spraying the starter fluid and the start once may have only been conquincidence. We need more info to diagnosis but it still sounds more starter related then injection related based on the limited information we have been provided.
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
