belt problem
Old Jun 10, 2009 | 02:50 PM
mikeselky85's Avatar
belt problem
I recently had put the original serpentine system on my car. I have every part and i bought the new belt. for some reason after i got it all hooked up the belt just seems to be way too loose even with the tensioner fully tightened. it idles without squeeking, but when you give it any throrrle a horrible squeal apears. should I do anything to my pulley surfaces? at the top of the belt it has so much play it will touch the belt on the water pump. please help!
Old Jun 10, 2009 | 04:26 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: belt problem
Do you have all stock sized pullys? And the AIR pump is installed?
Old Jun 10, 2009 | 05:06 PM
Re: belt problem
yes everything is stock pulleys and i do have the air pump even though its not being used
Old Jun 10, 2009 | 06:28 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: belt problem
if all is as you say the problem is #1 wrong size belt , or #2 mis-routed belt . good luck .
1992 Trans Am
May 10, 2023 07:19 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
