Removing O2 Sensor
Old Jun 19, 2009 | 05:09 PM
anomolee's Avatar
Removing O2 Sensor
I have a quesiton about removing my O2 sensor located on my exhaust manifold.
The sensor has a single wire attached and my quesiton is how is the wire attached? Is it a plug which is pressed on? Need to remove the wire to get the socket on the sensor.
Thanks for the help.
Old Jun 19, 2009 | 05:53 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Removing O2 Sensor
You can't use a regular socket. You need an 02 sensor socket. It's extra deep and has a slot cut up the side to slip the wire thru. About $10 at the local parts store.
Old Jun 19, 2009 | 09:57 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
that wire is not removable..
Old Jun 19, 2009 | 11:11 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
the wire itself is attatched to the sensor, but there should be a little plug/connector a few inches from the sensor (up the wire) that you can unclip and free the o2 sensor. You might need the O2 socket, or regular wrenches if you can get it from below...
SS-EXPRESS
Sep 28, 2015 09:14 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
Eric-86sc
Sep 7, 2015 02:10 PM
