Hard Start in Hot Weather After Sitting
Old Jun 20, 2009 | 07:29 PM
JeffD's Avatar
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
Ok I have 2 problems:
1. The days in Charleston are now nice and hot. When the car sits at work for 8-9 hours and I go to start the car it turns over fine but acts like it isn't getting fuel. What I have noticed is that if I turn the ignition on and off 3-4 times (leaving it "on" a few seconds before turning off) it will start right up. It also starts just fine in the morning. Ideas?
2. My car is also slightly hesitating during medium acceleration. If I am going about 35-40 and accelerate to 55-60 I can feel a slight hesitation as I accelerate (almost like the car has a pulsation or tugging feel to it). I have also noticed that if I am running the A/C that after 5-10 minutes if I pull to a stop the car almost acts like it is going to cut off and if I go to accelerate it almost shuts off. Ideas?
Thanks,
Jeff
Old Jun 21, 2009 | 12:25 PM
85t/alover's Avatar
Car: 1998 Camaro Z28
Transmission: 4L60E. Right now.
Axle/Gears: 10 bolt, Torsion diff, 3.73 gears.
Re: Hard Start in Hot Weather After Sitting
Hey, man. I'm in Columbia. I'm down in Charleston all the time. I work on an ambulance. Anyway, my idea would be the fuel pump. My 84 vette did the same thing. After I changed the pump I had no more problems.
Old Jun 28, 2009 | 01:03 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
hendersonville NC here wwwwoooooo!!!!! check the fuel filter too. if its dirty enough it could cause that. and its a cheap fix.
Old Jun 29, 2009 | 10:15 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
mine had the same problem, look at the fuel pressure regulator
Old Jun 29, 2009 | 10:27 PM
whatamidoing's Avatar
Car: 1986 camaro
Engine: 92 v8 5.7l
Transmission: stock
Axle/Gears: stock
hey i just got a 1986 camaro with a 92 v8 5.7 liter engine in it . the car was running really crappy so i had to change firing order on the car it was running alot better.. but still wasnt right about a week later i discovred the smog silinoid was disconnected from the terminal where it goes into the top of the engine also the electric was not pluged into the conponent. i did some research and found out the correct way to hook it up .. i started and drove the car about 5 blocks car seamed to be running better then ever smooth and more power . after i turned the car off and tryed to start it up the next day .. car does not start .. as u hold the exnition and pump the gas the engine gets slowly to full running speed as if its running and when i let go of the exnition it turnes off as quick as i let go ?? i also tryed removing the smog silinoid back to how i org found it still same story any suggestions ?? thanks
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
