Crappy when cold, decent when hot
Old Jun 29, 2009 | 04:30 PM
Hoffy91's Avatar
Car: 1982 Trans Am/1989 Iroc Z
Engine: T/A:1974 Corvette 350, Iroc:305 TPI
Transmission: T/A:Borg Warner 5-Speed, Iroc: Auto
Axle/Gears: T/A: Dana .44, Forgot Iroc
So my 89 iroc 305 is giving me crap. I finally got to drive it. When I fire it up, it chokes out and bogs and is literally not driveable. Anytime I hit the gas it just immediately sputters and chokes. But, after revving it a while I got it to rev somewhat smoothly. I pu it back in drive and then drove it more and it got better as it got hotter. Once it hit 220 degress it ran acceptably. I could hit the gas from a stop and it would go. It would sputter a little, but barely. Then I shut the car off for thirty minutes and started it before it was cold and the same damn thing started again. Bogged out until I got it running for about 5 minutes, then I could drive it.
I have the wrong tps on it it's from a v6, but would this be a cause to this problem? It seems to run fine when it's been running for a little while. I'm stumped and I need immediate help
Old Jun 29, 2009 | 10:30 PM
whatamidoing's Avatar
Car: 1986 camaro
Engine: 92 v8 5.7l
Transmission: stock
Axle/Gears: stock
Re: Crappy when cold, decent when hot
hey i just got a 1986 camaro with a 92 v8 5.7 liter engine in it . the car was running really crappy so i had to change firing order on the car it was running alot better.. but still wasnt right about a week later i discovred the smog silinoid was disconnected from the terminal where it goes into the top of the engine also the electric was not pluged into the conponent. i did some research and found out the correct way to hook it up .. i started and drove the car about 5 blocks car seamed to be running better then ever smooth and more power . after i turned the car off and tryed to start it up the next day .. car does not start .. as u hold the exnition and pump the gas the engine gets slowly to full running speed as if its running and when i let go of the exnition it turnes off as quick as i let go ?? i also tryed removing the smog silinoid back to how i org found it still same story any suggestions ?? thanks
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
hydrolic144
Sep 8, 2015 06:59 PM
scottmoyer
Sep 7, 2015 07:06 PM
