wont run unless I keep it at 3000rpm...
Old Jun 21, 2009 | 12:03 PM
1970 Buick's Avatar
Car: 1989 GTA
So, I replaced my stock runners on my 5.7 TPI with accel runners and while I was at it I stuck a quarter in the top of the FPR as alot of guys said that might help out a little. After everything was installed the engine wouldn't stay running unless I revved it up to 3000 rpm's or so. If I took my foot off the gas it would die instantly. I assumed it was a vacuum problem so I retightened every bolt. Same problem. So I took it all apart today to try and put it baqck stock and when I opened the FPR no gas ran out as it did the first time. The car has been sitting for a couple weeks without running at all. Anyone have any ideas on what my problem could be? Is it fuel related? By the way, the car ran just fine before I swapped the runners. It is an 89 GTA and everything else is stock. Thanks in advance.
Old Jun 21, 2009 | 01:59 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
Re: wont run unless I keep it at 3000rpm...
Try taking out the quarter.
Old Jun 21, 2009 | 04:40 PM
1970 Buick's Avatar
Car: 1989 GTA
Ok, quarter is out, everything is back together with new gaskets, bolts are tight. Same problem... Anymore help is appreciated!
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
