Custom inlet/return line routing on stock rail?
Old Jun 24, 2009 | 03:17 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I just converted to tpi and have a question about routing fuel lines. I've attached a picture to help display how I want to run the lines. Right now, my fuel lines come up on the driver's side, in front of the firewall, right next to the distributor. I have no need for the 9th injector, so I was thinking about using that hole for the new inlet and plugging the old inlet. For the return, I want to cut most of the old line and reroute it to exit near where the new inlet would be. Anyone see issues with what I want to do?
Old Jun 25, 2009 | 02:15 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Custom inlet/return line routing on stock rail?
I'm sorry I can't answer your question, but I am interested to find out the answer too. I have the stock settup/routing, but I have -6AN lines now....
Old Jun 25, 2009 | 02:45 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
that looks backwards to me.
my two lines dont go down the front of the fuel rails, they go down the back near the firewall. and there is a rail to rail in the front.
Old Jun 25, 2009 | 03:11 PM
Guest
Guest
Posts: n/a
The only problem you might have is setting up the new inlet, its an oddball fitting they used. IIRC there isnt much material to retap to a larger size either.
Old Jun 25, 2009 | 04:06 PM
HCR13's Avatar
Car: 1987 Trans Am
actually, now that I look at it a little better, I think it is possible IF you weld new bungs (-6AN in my case). I thought about deleting the stock FPR and just using a completely aftermarket FPR...
Can your design work, yes. But I'm not sure it can work without modifying the rails/inlet ports...
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kah992
Aug 19, 2015 02:55 PM
wayshegoes
Aug 17, 2015 12:00 PM
