Need info on heads
Old May 11, 2009 | 10:17 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
Need info on heads
Ok i've got a 88 camaro that had a tbi setup with the t-5 now I'm installing a tpi setup, new cam w/lifters it's duration is 224/234 and the lift is 465/488 new valve spring kit, but just don't know what to do with heads or just leave them stock the casting numbers are 14102187. Oh yeah planing to get new rockers but also don't know what to get 1.5 ratio or 1.6
Old May 11, 2009 | 10:31 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: Need info on heads
only thing you could really do is a port job on them, or just save up and get ya something like a new set of afr's....either way i hope you have someone that is good at tuning a tpi with that cam...
Old May 11, 2009 | 10:37 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
Why you say that? you think is to big of a cam?
Old May 11, 2009 | 10:44 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
no its not to big of a cam by any means....it just wont work well at all with a stock tune
Old May 11, 2009 | 10:51 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
I'm also port and polishing the intake manifold, runners and plenium. So your suggesting to also do the heads?
Old May 11, 2009 | 10:59 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
oh yeah...just be very carefull around the valve seats, use you gasket to port match you intake with your heads...anything you can do to "clean up" a factory head will be an improvement
Old May 11, 2009 | 11:06 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
Ok thanks. Appreciate the info, how much extra horsepower do you think that will boost me from the tbi swap to with what I'm doing?
Old May 11, 2009 | 11:10 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
mostly it'll be a big torque increase.....not sure on numbers...but trust me you'll like it
Old May 11, 2009 | 11:18 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Check to make sure that your stock heads will handle the .488" lift with 1.5 Rockers... (.520" lift with 1.6 rockers) before the valve seals get crushed.
scamaro355 is right.... you'll need to do some tuning to your prom for the car to run right.
I'm not sure what those 187's flow but if your porting everything before them you might as well do your heads as well... Find some 305 World SR heads they have 58 cc chambers and 170 cc intake ports...
my 2 cents
https://www.thirdgen.org/mods2
https://www.thirdgen.org/mods3
http://www.ws6transam.org/ported.html
Old May 11, 2009 | 11:26 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
Cool cool thanks for all that info guys, needed it before I put everything together, just wanted to do everything all at once so I won't have to do any more work to it for a while then I'll just go with a 350 later. By the way you think I should just go with the 1.6 ratio rockers?
Old May 12, 2009 | 07:59 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
i guess i missed the part about the 1.6 rockers with that cam, most of the time your lucky if you can get away with .480 lift with stock springs and no machine work. Just to be safe if you gonna use that cam with those heads id go with the 1.5 because unless you do some serious work to those heads anything past that most likely isnt gonna make much of a difference
Old Jun 21, 2009 | 12:06 PM
garys87camaro's Avatar
Car: 1987 IROC Z28
Engine: 355
I have an original 1987 Camaro IROC Z-28 with a 305 TPI automatic transmission. My plan is to replace it with a four bolt main 350 with 2.02, 1.60 valves, 64 cc chambers. I would like to keep the stock set-up for the TPI. Here’s my concerns: Will the intake bolt up to 2.02 heads and give enough swirl for the injection system to work adequately or should I look for 1.94" intake valves (1.60" exhaust optional), heads providing I include the rest of the package with adequate (cam, exhaust, etc.) will this work? I would like to stay with flat top pistons and adjust to around 10:1 ratio if possible.
Can anyone tell me what issues I will run into and recommendations in making the swap?
Old Jun 21, 2009 | 05:23 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
i can only think of 2 problems off the top of my head...the first being with heads...as far as the old school 2.02 heads the heads off of a L98 with the 1.94 valves will outflow them...and watch the amount of lift you go with on the cam...you could run into bind issues with the valvesprings...Hope you have someone that can do a tune on this for you because you WILL NEED IT!... good luck with the swap
Old Jun 25, 2009 | 08:10 AM
Car: 1987 IROC Z28
Engine: 355
Thanks for the feedback, I'm finding out the orginal intake for the 305 has a vortec style mounting for the two center bolts around the water jacket and the heads I use must have the same style. This is a problem unless I can replace the intake to something that will work for common 2.02 heads. Is the 350 TPI the same style manifold to head bolt up as the 305?
Old Jun 25, 2009 | 06:02 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
i was just reading my last thread....the 2.02 heads will not clear the 305's small bore so be carefull with cam choices...and the 350 intake is the same..the injectors are the only difference
Cornholio7979
Sep 20, 2018 02:31 AM
gta90
Sep 15, 2015 04:00 PM
509 camaro fan
Sep 6, 2015 10:43 AM
ambainb
Aug 29, 2015 12:43 AM
