injector size?
Old Jun 25, 2009 | 06:07 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
injector size?
i was just woundering how do you tell what poundage your injectors are. is there a number or mark that can tell you
steve
Old Jul 1, 2009 | 09:46 AM
89IROCZDG3's Avatar
Car: 89 Iroc Z
Engine: 5.7 TPI
Axle/Gears: Moser 9 inch , 3.50 gears
Re: injector size?
I don't know how to tell by looking but for a stock 5.7 you need 22# injectors
Old Jul 1, 2009 | 06:14 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
yea i need to know by looking at it i already know what the stock LB is thanks tho
Old Jul 1, 2009 | 06:44 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
Re: injector size?
The only real way to tell is take the number that is stamped or printed on the injector and then try and crossreference it. There are some sites that list specs by part number just try googling it.
Old Jul 1, 2009 | 09:01 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
ah ok i was afraid of that ok sounds good
Old Jul 1, 2009 | 11:53 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: injector size?
From an earlier post by one of the moderators:
Fuel injectors from 1985 - 1992
LB9
85-86 (1st Des) 17110872 (Bosch) (Ident by RP logo on side of Injector)
85-88 (2nd Des) 10108480 (Lucas)
87-88 (1st Des) 17111960 (Bosch) (Ident by RP logo on side of Injector)
89-92 17112283 (Stamped 5235435 or 86542)
89-92 17112284 (Stamped 5235434 or 86543)
L98
87-88 (1st Des) 17111961 (Bosch) (Ident by RP logo on side of Injector)
85-88 (2nd Des) 10108481 (Lucas) (Identified by "CAV" on side of injector)
89-92 17112285 (Stamped 5235437) OEM Injector # 17086544
89-92 17112286 (Stamped 5235436) OEM Injector # 17086545
LB8 (2.8L V6)
85-89 17111297 (Stamped 5235210)
LHO (3.1L V6)
90-92 17102747
3.8L Turbo
89-89 25519365
I believe your original injectors would be the Multec units built by GM, not a very reliable piece in general. They are usually gray in color.
Old Jul 2, 2009 | 04:58 PM
southbay08's Avatar
Re: injector size?
steve
Hi Steve, if you can get the numbers off of the injectors, and tell me what kind of horsepower you are running, I can tell you what size the injectors are.
Old Jul 3, 2009 | 07:24 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
ok let me look to see what the numbers are and i will post them when i get a chance
Old Jul 3, 2009 | 09:01 AM
southbay08's Avatar
Re: injector size?
ok great
Old Jul 3, 2009 | 03:36 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
ok so on this one there are 2 different numbers on the 2 sides first side is:
0 280 150 561 there is also a 957 on the plug and a 391 in the corner
on the other side is says:
fote-9f593-d9b they are pink purple in color at the top and they are ford brand
Old Jul 3, 2009 | 04:12 PM
southbay08's Avatar
Re: injector size?
They are 22lb injectors at 43.5psi
Old Jul 4, 2009 | 02:17 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
nice thanks for that how did you find that out
Old Jul 4, 2009 | 03:07 PM
southbay08's Avatar
Re: injector size?
my company is SouthBay Fuel Injectors.....this is what I do
Old Jul 5, 2009 | 05:15 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
oh nice good to know someone that works at a place like that do you guys do cleaning and testing on them as well
Old Jul 5, 2009 | 05:16 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: injector size?
nm answered my own question i might have more questions for you later about the cleaning
Old Jul 5, 2009 | 10:30 PM
southbay08's Avatar
Re: injector size?
no problem. Contact us at anytime.
PM
info@southbayfuelinjectors.com
516-492-6504
Old Jul 6, 2009 | 11:35 AM
meangreen92's Avatar
Car: 91 Formula
Re: injector size?
whats a good recommended replacement on a relatively stock car(bolt on 350 TPI, no internal work)??? 92 GTA btw
Old Jul 6, 2009 | 01:40 PM
southbay08's Avatar
Re: injector size?
we like the bosch 22lb design lll's. Nothing but great reviews
Old Jul 6, 2009 | 11:44 PM
Car: 91 Formula
Re: injector size?
thanks, may want to get some of them soon, odds are my factorys are worn out/inefficient
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
knight72
Aug 10, 2015 09:32 PM
