91 Camaro Fuel Pump?
Old Jun 27, 2009 | 05:21 PM
shephee's Avatar
Hi, I have a 91 Camaro Z28 convertible with a TPI. I just replaced the fuel pump and if you are familiar with this process you know how difficult it is. I have put the new pump filter & wire harness on and put the tank back up and connected the wiring. I have put about 3 gal of gas in it and started it up. The car will idle put when I push the accelerator it dies. I checked the fuel line at the TPI and I am getting fuel to that point at least. Not sure what it could be. Any suggestions or ideas will be appreciated. Not real sure what I could have done wrong.
Old Jun 27, 2009 | 05:58 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: 91 Camaro Fuel Pump?
i had a problem with my 91 kinda like that mine turned out to be the tps sensor was bad. it would idle rough and sometime wouldnt idle at all. so you could check that and also check the fuel pressure to make sure its got enough pressure. 34-47psi according to haynes manual is correct pressure.
Old Jun 28, 2009 | 01:41 PM
shephee's Avatar
Thanks Mick. I had to spend $50 to get a fuel pressure tester, but I got it none the less. I started the car and it said it had 40psi. With that being said I went ahead and put the rear all back together. I figure it must not be in the pump.
I have order the TPS and when it gets here and I get it installed I will let you know if that is it.
Old Jun 28, 2009 | 08:58 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
When was the last time the fuel
filter was changed
Old Jun 29, 2009 | 07:32 AM
shephee's Avatar
I changed the fuel filter about a month or two ago and I havent driven the car much since then. Maybe about 100 miles or so.
Old Jun 29, 2009 | 12:12 PM
shephee's Avatar
There is one thing I forgot to mention. Not sure if it is important or not. When I tested the fuel pressure it was at about 42 in the idle position, but when i pushed the accelerator it dropped off quite a bit like 10 to 15lbs. Is this normal? If not what might cause it to do this? The fuel pressure regulator, or could the TPS cause it?
Just thought I would mention it.
Old Jun 29, 2009 | 01:33 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
That is generally the sign of a bad pump. Not sure if that could be bad regulator though, I guess it's possible.
Old Jun 30, 2009 | 10:38 AM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
The first thing you need to do is get ahold of a scanner. That is always the first step whenever there is a problem.
If I remember right with the pump running and the vacuum line disconnected from the regulator your fuel pressure should be 45 psi. The way tpi cars work is the fuel pressure regulator does the low to mid load enrichment by increasing fuel pressure. The ecm does not pulse the injectors more until about 1/2 to WOT. When manifold vacuum drops fuel pressure is increased. Also when the ecm sees the TPS opening it increases ignition timing.
If your fuel pressure is going DOWN when you throttle it there is obviously a fuel supply issue somewhere. Your engine is leaning out to the point that it stalls and dies when this happens.
If you just replaced the fuel pump the next place to look is the fuel filter. Then the fuel pressure regulator. If you replace all these things and you have access to an air gun you can spray some carb cleaner in the fuel lines and blow them out.
Keep us posted.
Old Jun 30, 2009 | 11:32 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Pull the vacuum line off the pressure regulator, if gas comes out of it you need to replace the regulator.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
