305 TPI Aftermarket Camshaft Specs?
Old Jul 7, 2009 | 12:50 PM
Racer X79's Avatar
Car: 1988 IROC Z28
Engine: 305 H.O. LB9
Transmission: T5 5-Speed
Axle/Gears: 3.45
It's finally time to rebuild the LB9 305 in my '91 Z28 5-speed. I'd like to upgrade the camshaft, but I want to stick with the 19lb injectors(I installed new Bosch injectors last year), the stock computer, etc....
I've already done all the "free" TPI mods, it has flowmaster exhaust, it will have headers/y pipe w/no converters, and the stock 3.42 rear. I'm not looking to go overboard, I'd just like to put in the new cam and leave the rest of the long block/electronics stock. Any ideas on cam size would be great, or if anyone knows of a proven combo...that would be great also.
Old Jul 7, 2009 | 02:46 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: 305 TPI Aftermarket Camshaft Specs?
I just recently upgraded my L69 with TPI, installing an LT1 cam. After a lot of research, this came out as about the most lift the stock engine could handle without any Head Mods. Runs very strong, idles great. Your new injectors will be fine, but you might need a slight tune on the ECM to take advantage of the cam. Might get by without it, but I have MAF and it is a little more forgiving on changes. While you are changing the cam, be sure to change the timing chain as well- good insurance. Might also want to install new springs and valve seals.
Old Jul 7, 2009 | 03:23 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I have an LT4 cam in my LB9 and it runs hard with it. With this cam however you will need a tune. Its not even the hot cam but its got a nice idle for a 305 and a ton more ***** than any N/A 305 should have lol.
Old Jul 8, 2009 | 12:38 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I basically have the same car. Went with comp cams xr258hr12. Love the cam. Great power and torque in the 2-5K range. However, you will need a tune even with a mild cam. My car ran without a tune for about 10000 miles. Needless to say, it needed new plugs at that point. With the stock program, chances are the car will run too rich down low, and too lean up high. A good wide band tune makes a huge difference in unleashing the mods you have done to the engine.
The LT1 cam is not worth putting in, since it is not much different than the stock L98 cam that is in your car.
Old Jul 9, 2009 | 03:49 PM
NY3RDGEN's Avatar
Car: Trans Am, Corvette
Engine: LB9, LT1
Transmission: 700R4, 4L60
Axle/Gears: 373, 259
Crane 2032, or go to TPIS.com, look under L98 cams, they have a few that work great with an LB9, id also port out the plenum and consider aftermarket runners- TPIS< AS&M or SLP's. Youll be reving way higher with a decent cam in there. so opening up the intake will take better advantage of the new cam.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
