383 advice on my build
Old Jul 8, 2009 | 09:36 PM
louflemm's Avatar
right now i have a 355 on a stand just ordered the eagle 383 flat top rotating assembly. i have a holly contender dual plane manifold with a holly 650 double pumper. i was wondering what kind of heads and cam to put in it. its going to be a daily driver but doesnt have to pass emissions. i have a 9bolt with 373s. debating on weather to use a turbo 400 for 100$ or use my 700r4. so the question is what kind of heads and cam will do justice. i want max horsepower on pumpgas.
Old Jul 8, 2009 | 09:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 advice on my build
Better intake and carb would be best to take advantage of a 383 with good heads and healthy cam.
With that current carb/intake setup i wouldnt go too crazy with the heads/cam setup. Flat tops will make around 11 to 1 compression with 64cc chambers so you will need aluminum heads to run pumpgas.
Your looking for AFR 195s, Canfield 195's, Brodix race rite or IK200's, Dart pro 1 platinum 200's, Trickflow 195's etc. Those are the better aluminum heads out there.
Is it a roller cam block or is it going to be flat tappet?
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
gixxer92
Sep 1, 2015 04:32 PM
