hesitation problem
Old Jul 9, 2009 | 02:03 PM
davidGTA's Avatar
hesitation problem
i cant figure it out.
i just bought a 89 gta with a l98, the car was running fine when it had lt1 injectors @ 58 psi, other than the fact it was running rich and sometimes the injectors didn't want to work. then i swapped to some bosch 3 #22 injectors and tuned the fuel pressure to 44psi.
problem is right at start up the car stumbles and sounds like it is about to die but if i burp the thottle it with smoothen out and run fine. untill i try to drive it. i will put it in gear and it hesitates bad when i give it some gas, but about 2 minutes later with will have problems and will run great.
i figured it could be a little lean so i bumped the fuel up to 50 psi and had the same problem. timing is at 6* BTDC, and it's a pretty stock engine, just has siamised plenum and thats about it.
any ideas?
Old Jul 11, 2009 | 01:40 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: hesitation problem
Well hesitation issures are usually caused by a lean mixture or a timing probem. Check the car for vacuum leaks and also pull a few spark plugs and see what color they are.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
