new fuel pressure reg, low pressure
Old Jul 10, 2009 | 09:46 AM
suh_wheat_86305's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
fuel pump replaced, but still had problems. We put a guage on the fuel rail and drove it... pressure dropped to about 20 psi above 2500 rpm or when pedal was floored. Now, a new regulator, but still not holding pressure. If we pinch the return line, pressure goes up to over 80psi. Otherwise, we still see low pressure at revs. Mechanic is stumped. Is there a vacuum line to the FPR? If so, what does it do?
any ideas otherwise... please?!
Old Jul 10, 2009 | 02:14 PM
jstuart83's Avatar
Re: new fuel pressure reg, low pressure
yes there is suppose to be a vacuum hose that goes to the fuel pump regulator there has to be some type of input to change the output of the regulator. If i remember correctly its on the very top of the regulator at least on my 87 gta 5.7
Old Jul 10, 2009 | 05:02 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
It gets connected to the top of the regulator and then to the plenum. The mechanic is lousy if he cant figure that out.
Old Jul 10, 2009 | 09:38 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
RUN AWAY FAST
Old Jul 11, 2009 | 05:08 PM
Car: 1986 Trans Am
He figured out the vacuum, I'm sure. That was my question... but I am starting to wonder...
The shop installed a Mallory adjustable FPR. This was their answer to the dropping fuel pressure problem, after they put in a new spring & diaphram in the old FPR
They then left the original FPR alone and added the Mallory FPR to the return line. It seemed to work at first, but out on the street in was back to the same old problem... the car will not accelerate past 2500 rpm or so... sometimes it will rev to 3k. When it falls down at 2500 rpm or so, nothing will let it gain revs. If the pedal is depressed or even floored, not much seems to happen, just bogs and goes nowhere. In park or neutral, it will rev right up to 4k+, no problem, no hesitation.
I just got the car back for the weekend... it is actually drivable. I still have rented a pressure tester. I will put it back on and drive it, but I know I will see the pressure drop at aroung 2500 rpm... it drops to about 20, especially when it starts to bog... flooring it just make it worse.
Can this possible have anything to do with a new transmission installed with a 4k converter?
We are all at a lose at to what is causing the fuel pressure to drop... an open injector, I guess, but would that make it bog down and fall on its face?
Old Jul 11, 2009 | 07:22 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Well, adding the second regulator was wrong IMO. Did they change the fuel filter? Maybe they left the diaphragm out of the main regulator and depended upon the secondary regulator to do the work. Perhaps the new regulator has now failed. The fuel pump should be able to supply 8 injectors stuck wide open so 1 wouldn't be a problem for it.
Old Jul 11, 2009 | 08:39 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
jklein337
Sep 19, 2018 06:23 PM
dcbsracing007
Aug 18, 2015 07:24 AM
jackhammer
Aug 15, 2015 10:04 PM
Kaweh
Aug 9, 2015 02:54 PM
3rdgenparts
Aug 6, 2015 09:03 AM
