TPI wont start Need Help
Old Jul 10, 2009 | 01:08 PM
Hub454's Avatar
I have a 305 TPI motor from a 90 camaro. I cannot get any power to the distributer. If flashes (12) everything is working on the diagnostics. Does any one have any ideas? I have pulled the wires from the distributer and they are not sending any power through to the distributer when the key is on or cranking over.
Old Jul 10, 2009 | 02:04 PM
jstuart83's Avatar
Re: TPI wont start Need Help
have you checked your fuse box to make sure there are not any blown fuses
Old Jul 11, 2009 | 07:05 AM
Hub454's Avatar
I checked and no blown fuses. Any other thoughts?
Old Jul 11, 2009 | 07:52 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
is this in a Camaro? if not are you using a ECM from a Camaro with VATS?
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
