stripped out bolts on superram plenum, Options?
Old Jul 14, 2009 | 08:22 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Well I recently had a bad backfire through the intake and it popped the super ram plenum from the runners on one side as well as sprung the lid. So I've got a bunch of stripped holes. Best solution is to get them welded and then retap them. What are my other options? I'm not sure helicoil is the W2G. Has anyone changed out the lower bolts to studs or done something else? I had slotted the screws which does really help with installation.
Old Jul 14, 2009 | 02:22 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: stripped out bolts on superram plenum, Options?
retap one size over would be my best suggestion. Or you can take it to a machine shop and have then do it if you have the money.
Old Sep 20, 2009 | 03:02 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Which route did you end up going? I have 3 stripped bolts in my plenum and want to know how to fix them.
Old Sep 20, 2009 | 04:26 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Can you use some Heli-coils. They work great and once installed cannot strip. They are steel inserts.
Old Sep 20, 2009 | 04:28 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
But the Superram is aluminum, so I don't know how that would hold up. Some people suggest not to use them.
Old Sep 20, 2009 | 06:20 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
What would be the difference aluminum or steel? the holes are just drilled and tapped to begin with, so a helicoil should be just fine.
Old Sep 20, 2009 | 10:47 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If that is what I need to do, Ill try it. I may just get it welded and drill and tap it to the stock size.
Old Sep 21, 2009 | 12:48 AM
Guest
Guest
Posts: n/a
Why do they say not to use them? I want to hear that.
They're stainless steel. I put some into an aluminum manifold about 15 years ago and its still just fine.
Old Sep 21, 2009 | 12:51 AM
burnout88's Avatar
Car: 88 IROC
I have even used them in aluminum heads to repair damaged spark plug holes.
Old Sep 21, 2009 | 01:14 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What makes them stay? The spring design?
Old Sep 21, 2009 | 11:48 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Yes, the insertion tool winds the spring, thus making it smaller in circumference to install. When installed, it is still under tension. They don't come out and they don't strip nearly as easily as the aluminum does. Good all the way around.
evilstuie
Jan 9, 2020 08:29 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
deracer
Apr 11, 2016 12:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
