Okay Okay..
Old Jul 26, 2009 | 07:36 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Okay Okay..
First I learned that TPIS gets there Runneres made by Arizona Speed and Marine, Awesome!!! (I have a set from ASM) Then I found out that either set will work with the Big Mouth Base, Excellent. (Sold my Ported stock base plate with the 350). I really want to see if I should mate my setup to my LB9. Thanks!!!!!!!!! https://www.thirdgen.org/forums/tech...-my-setup.html
Old Jul 29, 2009 | 04:06 PM
Re: Okay Okay..
Okay, are there any Dyno Numbers/Graphs for Runners on a 5.0???
Old Aug 2, 2009 | 06:13 PM
Re: Okay Okay..
Agh... Someone throw me some info!
Old Aug 4, 2009 | 01:55 PM
Re: Okay Okay..
Bump...
Old Oct 5, 2009 | 09:52 PM
Re: Okay Okay..
Agh, Disregard. No longer in pursuit of the LB9. This seems to be asked constantly, What type of numbers does the LTR, Big mouth base put out??? With this setup am I better off with a 350 or a 383???
What about going bigger than a 383 with the TPI Setup???
spdhawk77
Apr 12, 2014 09:04 AM
72SSboy
Aug 15, 2013 07:48 AM
Rcaldw9
Oct 19, 2012 11:11 PM
jamienoel
Aug 30, 2010 02:03 PM
