tbi rough idle
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
tbi rough idle
okay.. 89 formula 305 tbi with headers. i have replaced everything except the distributor itself and i do mean everything.. the car is practically a 2014 when it comes to all sensors,connectors,seals,vacuums,electrical components etc. new tps,egr,aic,map,fuel pump,injectors,tbi rebuilt, etc.. runs great but when sitting at idle seams like a random miss or something. just idles rough. dont know if it could be the headers causing it or something im over looking. ive had this same prob since i bought the car and any advice would be appreciated. just in case it matters its a 5 speed. thanks
Axle/Gears: 10 Bolt 2.73 Open
Re: tbi rough idle
How many miles on this engine?
When you have a timing light on it, does the timing hold pretty steady, or jump around?
Car: 89 Formula
Engine: 305 T.B.I.
Re: tbi rough idle
180k on the engine. ive never accually put a light on it. ive always timed it by ear and by how it cranks best and run best.. think it might be worn chain?
Re: tbi rough idle
Re: tbi rough idle
At that mileage, a worn chain is possible. It's free to check, and eliminate as a possibility.
From my own experience with the L03 in my '91, and everything I've read here, these motors don't like a ton of advance. 4* to 6* BTDC seems to be the max. If fighting an issue, I'd go back to stock, which is straight up if I recall correctly, and tweak it from there. Don't forget to disconnect the EST bypass wire (I think that's what it's called) when checking the base timing.
Car: 89 Formula
Engine: 305 T.B.I.
Re: tbi rough idle
