EGR temp sensor has been discontinued
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: EGR temp sensor has been discontinued
That's ironic. I called Autozone yesterday to buy a coolant fan relay for my wives 2000 mercury mystique. According to the computer, there was 5 on hand. I got to the store only to find out that the local Ford dealership took all 5 one month ago. So I special ordered 1 from a San Diego store.
can this time delay switch be an altenernative to the EGR Temp Switch?
http://www.autozone.com/autozone/par...68613_173005_0_
http://www.google.com/url?sa=t&sourc...Y2zmV4-ybZydrw
The EGR Temp Switch isn't used by the ECM to tell it to open the EGR valve. Rather, the EGR Temp Switch tells the ECM if the EGR has opened.
When the ECM commands (requests??) EGR, it expects to see the EGR Temp Switch close. If it remains open, the ECM will set the SES light.
An SES light that is on during an emissions test is typically an automatic FAIL.
My EGR valve was bad, but I never got a code. I replaced the valve. But thought about taking the switch off to test it. But if it's only purpose is to send an SES light and doesn't affect the EGR valve operation. Then I won't bother trying to pull it as it was stuck last time I tried pulling it.
I still get knock counts on acceleration under load. So, I'll just test the solenoid then.
So, the only thing the switch does is throw a code?
I beleive that a EGR troublecode is logged when the ECM doesnt get a grounding signal from the EGR Temp Switch when the engine reaches normal operating temp. How does the ECM know when the engine is at normal operating temp? Coolant Temp Sensor or Coolant Temp Sender ( not sure which one it is but one is for the ECM and the other is for the Temp Gauge).
This explains why you get a Code 32. And I didn't see anything that says the switch sends a signal to activate the EGR valve. It seems the switch is just a "diagnostic" switch to help tell you something is wrong with the EGR system.
http://members.shaw.ca/corvette86/Code%2032.pdf
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
yeah once i got mine my code 32 went away, now i have a code 12, and a coolant temp low reading code
yeah i know josh, SES light always stays on with that code 12 annoying.
yeah that was is brand new lol. need to do that sooner or later.
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
"Can anyone tell me where is the egr time delay switch? Thanks"
It is on the front of the manifold next to the CTS. They look similar. Yellow and black wire goes to the CTS. The other one is the time delay.
I found a solution to the EGR Temp Switch. YOu'll need a aftermarket temp switch. Ill get to you guys later. Im in class right now. Garenteed to work by using your coolant temp for operation.
Ok guys. Go to Autozone.com and search this part number: 733653
( http://www.autozone.com/autozone/par...ier=267187_0_0_ )
Since my EGR Temp Switch grounds itself at around 132* at the EGR temp Switch base, all you would have to do is put in the temp. probe into the top radiator hose and clamp it. Dont use the foam that is included, itll just make a large leak. So here is what you do. Remove upper radiator hose, insert probe about 1-3 inches inside the hose. clamp it down. THen get a votimeter and put it in continuety mode. put the voltimeter leads to each end of the switch terminals. Then turn on the 3rd Gen and watch the temp gauge. Once the temperature reads 132*, go to the switch and slowly turn the **** until the voltimeter recieves a reading. The reading that the voltimeter will be seeing is that the switch is being adjusted to ground at the temp that the coolant is at. Once you achieve the switch to ground itself at 132*, you can now move on to the EGRE wire. Connect the EGR wire with the provided blue wire to one end of the switch terminal. Then connect the other terminal to any groundpoint. now your done. If I confused anyone, please let me know and Ill clear it up a bit.
Any thoughts on my last post? Anyone?
Its gotta work. The probe acts as the heat sensing device which triggers the switch/**** to ground at the adjusted temperature (approx 132*). It will not open the circuit until the coolant temp drops to under 132* the good thing is that the temp switch doesn't require power to work. So it should work. I'm gonna test it out when I buy a new coolant fan. But this fan I'm gonna wire it witht he temp switch instead of using the ECM's turn-on lead. Hopefully it won't take long till I buy a fan and switch.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Latest availability.
Would need to splice the wire for a 3rd Gen
http://www.keenparts.com/pages/detai...=370196&PL=131
Passed the last 3 smogs with no problems. My understanding is that it is a diagnostic switch that might indicate a problem because the EGR function did not work. My EGR circuit works fine.
That's the switch in my 88 Corvette. I bought the car 5 years ago and the switch has never worked, no more wire lead on top. I bought a new one, but with a real good tune I never get the check engine light so haven't installed it yet.
As for the tuning process, IIRC, you can max out one of the settings which will make the ECM think that the EGR is working properly. I had the option to disable my EGR and remove the EGR valve when a fellow member burned me a EPROM, but I weighed my options and decided to keep my engine like how it is supposed to be.
Car: 82 Z28
Transmission: T400
The switch tells the ECM that exh gas is flowing into engine when the ECM has commanded the EGR valve to open.
Code 32-
"A egr failure will set this code.
Either a faulty EGR valve, EGR temp. switch or the EGR control solenoid. .
When the egr solenoid is operating properly, the ecm will activate it, allowing vacuum to open the egr valve, this in turn will allow the hot exhaust gases to circulate through the egr valve
and the EGR temp. switch will heat up until it reaches its activation temperature, it will then close and send a grounded signal back to the ECM telling it the EGR conditions have been met.
If the switch is closed on start up or does not close when the operating parameters are met,
code 32 will be set".
Well I did put a multimeter to the lead on the egr temp switch which grounded when the temp reached 132* (thermal lazer thermometer) with the multimeter in continuity. So I believe I'm correct in my behalf. After all, the switch does act like a little christmas light flasher, it bends with heat.
Car: 82 Z28
Transmission: T400
Car: 1987 Camaro IROC-Z
Engine: LB9
I think I may have found something. I ordered one yesterday. aside of possibly having to lengthen the wire for it I think it will work rather well. We can thank the C4 vette' crowd
http://www.parts123.com/parts123/yb....5Z5Z50000050F#
Hello . I have found this item at Napa in Harrisburg Pa. it's $18.oo bucks :-)
Part # is > CRB 229130....
This is for 1988 Iroc's TPI.. 305 might fit 350 also... good luck
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Hopefully it's available to those that need one. NAPA On-Line won't allow mail order; only in-store pickup. The stores around me don't stock it and it has to be ordered. We've all been down THAT road before (read: NLA - no longer available).
Ok maybe i can help..... I live here in harrisburg, So for anyone needing that item give me an IM on here or at Meta1909@hotmail.com... we can work something out ... with a small finders fee :>)
P.S just kidding about the last part
ERG Temp Sensor Part # CRB 229130 for Tpi Iroc's 1988
Have a good one all ........
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
That's good news. Guess I can ditch the ones I have been saving. lol
guy on ebays selling one for 400$ brand new.. efff.
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
man what a nightmare i am having finding this stupid egr temp sensor
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: 5.7 L98
part number on that 1 is 14087415 which crosses to a delco 212 336
our cars is 14087416 crossing in delco to 212 337
any idea what the diff is?
Engine: Lb9
Transmission: M20
I think it's just the pigtail length ? I have a few used ones Ill check today and see If I can tell.
Engine: 5.7 L98
id appreciate it. thanks
id buy a used camaro/firebird one if u got 1 to sell
Engine: 5.7 L98
Engine: LB9
Figure I'll give an update. I installed this (c4 corvette one) months ago now... It works perfect, you DO have to cut and extend the pigtail about 6-8 inches for it to reach (took 15 minutes to do). It threads into the EGR just the same. Longest my SES lamp has been off since I've owned the car.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
After reading that article I adjusted the EGR temp switch in my '87 vette & solved my code 32 problem. The shaft is threaded and moved quite easily. I turned mine out about 3 turns & problem solved.
I haven't read the whole thread but the Vette version of the temp switch has been available for a few months now.
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. So, when my EGR temp switch goes bad, can I just plug the EGR vacuum line (while leaving it 'connected') and disconect the switch wire (while leaving it looking 'connected') and live happily ever after for free?
.. I disconnected and plugged the EGR vacuum hose on my Monte today and when I drove it to the store, it ran like new again the whole way, instead of sometimes good, sometimes rough... At first, I was surprised it was running so well, then I remembered disconnecting/plugging the hose... I don't think the Monte has that EGR temp switch, it doesn't know if the EGR is actually doing anything (besides making it run crappy)...
hi guys I own an Iroc 86 TPI and my problem is that in the mornings I turn on the car the SES light comes on,I let it warm on for 5 min. I turn it off for a 1 min and the turn it on and the light is gone for the rest of the day and when I check for codes it give me code 32 what it could be?you think is the egr valve I replace it but I have read that even new ones can go bad really soon any help would be appreciate it
Transmission: Many
Axle/Gears: Many
.. If you would have read the thread above, you would realize the Code 32 is because the EGR temp switch/sensor is shorted out and bad when the engine was first started... the 2nd time you start it, the engine is warm and the ECM thinks the switch is now closing normally... try simply unplugging the EGR temp switch and see if all is well after that...
.. A Vette owner mentioned above 'adjusting' the switch by turning the wire mount, but I'm wondering if he adjusted it... or merely broke it to an 'open' circuit condition...
Just reread my FSM: a code 32 will be thrown if the switch doesn't close when the engine warms up---so no I didn't break it. Simply disconnecting the switch won't solve a code 32 problem, just move it from start up to warmed up.
Merry Christmas
Merry Christmas
Last edited by 3D87C4; Dec 25, 2011 at 05:26 PM. Reason: reread FSM & revised response accordingly
Vette
