Want to Tune My LT1, where to get started?
Hi,
I have a 96 lt1 from an impala ss, going into the 88 base camaro.
I am going to need VATS removed, and probably reprogram for my gear ratio / tire size, other odds and ends. Once I get the car running, I will want to play with the tuning end of things.
From what I read of Tuner pro, sounds like the software I would be using, unless you guys tink tunercat is better for the obd ii computer.
What hardware will I need?
Will I be able to flash it with bins, that have VATS, EGR, removed ?
1992 Trans Am
Aug 8, 2015 08:16 PM
