Car starts and immediately dies
Old Aug 3, 2009 | 06:13 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Car is 1989 Iroc 350 TPI. The car will fire up and immediately die. I open the hood, and tap the group of relays on the DS firewall and bam, she fires right up and runs fine. I have swapped the relays with no affect. I also have a CEL "mass air low". Any ideas? Thanks.
Old Aug 4, 2009 | 12:39 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Car starts and immediately dies
replace your mass flow sensor. if you unplug it your car ether wont start or start and die as it is. i just replaced mine for 42$ and its simple to replace.
Old Aug 4, 2009 | 12:05 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
check the plugs on the relays, over time the insulation can slide down and expose bare wire that can short out and cause many problems.
Old Aug 4, 2009 | 12:14 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
also check the wiring at the MAF. probably wouldn't hurt you to get some electrical component cleaner and spray that maf down... debris on the wire would mess with your signal as well.
Old Aug 4, 2009 | 02:21 PM
remltr's Avatar
I see that some of the insulation indeed has slipped down. Is there a tool to release the wiring from the connectors?
Old Aug 4, 2009 | 02:27 PM
thunder85's Avatar
Engine: 5.7L w/hsr
yes... or you can just get a fine piece of strong wire that will let you pop that tab down which holds the wire in place. i have small terminal block screwdrivers that i use.
Old Aug 4, 2009 | 04:32 PM
When this happened on my car I just individually wrapped each wire with black electrical tape.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
