TPI ON DIFF MOTOR......
Old Aug 4, 2009 | 10:00 PM
DANNY25SS's Avatar
Car: 92' Formula T-Top
Engine: L98 With Custom CAI
Transmission: BUILT 700R4 with B&M Mods
can the tpi be used on another motor with mods to go with the engine change? i have other motors that would be great replacement once the time comes one is an old street stock motor i ran quick specs... 358 cuin 4 bolt block stock 3.48 stroke with 5.7 rods speed pro coated hyper pistons comp .501 magnum cam 244 @ 50* 2500-6500 rpm (i know ill need to change its for oval track lol) puts out just shy of 11:1 compression with 906 vortec heads 1.94/1.50 stainless valves with 1.6 roller rockers... ran an rpm airgap with this and a AED 750HP carb... it knew how to get up and go lol... i have seen some vortec threads but i was wondering on some new input as how the tpi setup takes to it and what kind of mods ill need or should do... the machine work isnt an issue its just will it work is it worth it?.....
Old Aug 6, 2009 | 12:25 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: TPI ON DIFF MOTOR......
Must change your lower intake because of the vortec heads. And definitly yank that cam. By putting it under a tpi your doing nothing but hurting the top end unless you buy a stealth ram setup or some slp runners and hog the hell out of them. Tpi will run out of breath around 4800 rpms, would definetly recommend a better intake setup and bigger injectors (24#). Then an adjustable fuel pressure regulater and a good fuel pump. Then a good tune on the computer and ur set.
Orr89RocZ
Oct 7, 2015 12:47 PM
draco
Oct 4, 2015 09:25 PM
ydnar417
Sep 23, 2015 05:57 AM
mddaniel
Sep 8, 2015 05:16 PM
Sanjay
Aug 12, 2015 03:41 PM
