Ignition problem...going crazy!!
Old Aug 6, 2009 | 05:27 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
87 tpi Iroc. It has a pretty good skip under throttle, heres what i did so far...New plugs, cap, rotor, and wires. Now after I replaced these the car ran great for like 2 days and the misfire came back. I than replaced the ignition module and when I took the two wires off the module the plug that the two wires are in crumbled in my hand. So I just put the two wires on the module and put it all back together and not it runs worse than ever. Do you guys think I should put silicone or dielectric grease around those 2 wires? Can the bare wires be arching on the base of the distributor? I am at a complete blank why the car ran great and now its skipping again. I am pretty sure its ingnition related. I have been around motors for along time and I know a skip when I feel it..lol I am just new to this tpi stuff, is there something I am overlooking? I even took the shaft out of the dizzy and cleaned all the rust off of it, thinking maybe it was that..( the car sat for 10 yrs) I am drawing a blank here....any ideas what to look for?..Thanks guys!!
Old Aug 6, 2009 | 12:12 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: Ignition problem...going crazy!!
What spark plugs are you running in it and what gap?
Old Aug 6, 2009 | 05:32 PM
NY87Iroc's Avatar
Ac delco r43ts I believe off te top of my head. I put a new magnetic pickup in it today and it starts and idles alot better...Going to take it for a ride later and see its its better.
Old Aug 6, 2009 | 08:07 PM
NY87Iroc's Avatar
Well just got back from a 10 mile trip and it ran the best it ever has!! Def was the magnetic pickup, starts better, idles better and no skips!!
Pac J
May 17, 2020 10:44 AM
Gunner242
Dec 25, 2015 04:49 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
