Sputtering
Old Aug 11, 2009 | 10:04 AM
BJSX23IROC's Avatar
Car: 87' IROCZ-Z28
Engine: 350 T.P.I Bolt-ons
Axle/Gears: 3.73 posi
Sputtering
Recently I have been having troubles with first start up of my car. When I start it one of two things happen. The first is that it when it starts and i put the car in drive or reverse it stalls. I have had to restart the car up to 6 times until it acts like it is going to stall and then the idle seems to adjust so it holds. The second problem is also on start up. It has only been doing it recently and not everytime but when started the idle is real rough sort of like i have a big cam in it or something. It goes into drive fine but when i am stopped and hit the gas it starts sputtering and cutting out until it shifts into second. I dont know if this could be from the incorrect air the fuel ratio or some other problem. I tried checking the spark plug wires to make sure none of them had been burned on my headers to see if that would be causing a misfire but they all looked fine. If anyone has any ideas i would appreciate it.
Old Aug 13, 2009 | 09:27 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: Sputtering
There are a few things that you can check. First check the IAC to make sure that it is not gunked up. make sure that behind the throttle blades there is no carbon as well. make sure that you have a good fuel pressure and i would change the plugs and wires if you have not in a while. possible cap and rotor
Old Aug 13, 2009 | 10:33 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: Sputtering
Does it EVER run well?
db057
Apr 28, 2019 07:45 AM
Andrew6.688
Dec 13, 2015 10:59 AM
TBICamaro
Jan 2, 2001 10:19 AM
84Berlinetta305
Jan 1, 2001 04:44 PM
Locry
Dec 28, 2000 11:46 PM
