Vacuum Lines Need Help
Old Aug 12, 2009 | 07:08 PM
Matemk's Avatar
What line is supposed to connect here, the empty one behind the TPS
The one above it goes into the Valve Cover on Passanger Side.
Old Aug 12, 2009 | 07:30 PM
Matemk's Avatar
Re: Vacuum Lines Need Help
forgot to add, 1990 Camaro 350 TPI
Old Aug 12, 2009 | 09:39 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
It should connect to your evap. cannister.
Old Aug 12, 2009 | 10:15 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i agree with the above
Old Aug 12, 2009 | 11:04 PM
Matemk's Avatar
the line coming off the evap canister is alot smaller than what will fit on this.
and off the evap canister it has the main line that goes back to the tank, a line that T's off and goes to the cruise control and then into the check valve on the passanger side, and one nipple with nothing off of it, that should be the vent.
The line that T's off and is currently on the check valve, does that need to go to the manifold?
will get pic of how it is set up tomorrow.
Old Aug 12, 2009 | 11:45 PM
Car: 91 Trans Am
Engine: 355 TPI
i'll look at mine tomorrow morning and see how shes set up
Old Aug 13, 2009 | 08:39 AM
Car: 91 Trans Am
Engine: 355 TPI
ok it goes from the TB to the evap canister, a line goes from the TB to a little splitter and then to the evap canister on the smaller line.....i hope this helps
Old Aug 13, 2009 | 01:10 PM
Matemk's Avatar
if any one has time could they take a couple pics of how the vacuum lines are supposed to be set up, ive tried looking at the vacuum diagram with no luck.
i need pics of the check valve and what lines go into it, the FPR line, MAP line, evap canister lines, and passenger side throttle body. anything would be greatly appreciated
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
