New heads
Old Jul 30, 2009 | 01:53 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
New heads
Hi!
I am about to swap my heads for a pair of new ones, and wounder if any of you have a simular combo like mine and can recomend a pair.
Old Jul 30, 2009 | 05:28 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: New heads
I would just get the heads you have ported and reconditioned.
Old Jul 30, 2009 | 11:21 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New heads
I have already spent 400usd in restoration.
And my heads have never been any good ,some studs are not straight and i have to use different length of the pushrods and lashcaps to get it right.
No more trickflow for me.
AFR 180 or 195?
Sportsman II ?
Old Jul 31, 2009 | 01:02 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: New heads
you need to spend the time on your current heads. if they are tpi heads you are in good shape. get a good machine shop that is used to working on American heads.
you should not have the problems you have unless the machining is bad.
you need stainless steel valves, the correct springs for you cam.
get the studs pulled out and put in screw in studs. they reason they are crooked if because you are pulling them out with springs and a cam that is too much for them.
that can also be the cause of your other problems.
what cam are you running?
Old Jul 31, 2009 | 01:33 AM
Guest
Guest
Posts: n/a
Re: New heads
He said he has trick flow twisted wedge, I dont know if they are G1 or G2. Might be best if they are really that bad from the description (how's the power output?) to replace them. If you get rid of those, I'd get some AFR 195's. The sportsman II are a big step backwards, you'd either need to run the Pro 1, or some very well ported Brodix Track 1. I'd stick with the AFR's personally.
Old Jul 31, 2009 | 06:11 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New heads
Ok
No way i spend another 400usd or more on those heads.
There was a proffessional machineshop that worked on them and they say that those heads are bad from beginning.
The springs are mached and the car runns good but i dont like the noice of the heads,its sound like it will broke any time.
I am pulling 280rwhp.
I think that a pair of AFR eliminator 195 could add some 20hp?
My stock tpi heads didnt sound like that.
Its very hard to get the twisted valves to center on the roller.
Check my setup in the sig.
Old Aug 12, 2009 | 08:59 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New heads
Someone running these?
Any good?
http://cgi.ebay.com/ebaymotors/Patri...Q5fAccessories
Old Aug 12, 2009 | 12:53 PM
Guest
Guest
Posts: n/a
Re: New heads
You would be better off sticking with what you have now.
If you can afford the AFR heads, they are the way to go.
Old Aug 12, 2009 | 12:56 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: New heads
Originally Posted by Firebird sweden
I've not heard good things about patriot heads....AFR's would be my recommendation....
Old Aug 12, 2009 | 01:08 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New heads
Ok thanks
180 or 195 AFR for my combo?
Old Aug 12, 2009 | 01:24 PM
Engine: L98 494hp
Re: New heads
195cc for sure
Old Aug 12, 2009 | 02:49 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New heads
Ok
I dont now why some of you like the twisted wedge heads, when they are so much trubble to get match.
I just whant heads that i can trust.
And dont sound like they would brake any minute.
Old Aug 12, 2009 | 03:05 PM
Guest
Guest
Posts: n/a
Re: New heads
I dont know anyone other than a few that had the twisted wedge G1 (first version) that had anywhere near the issues you've had with yours... and those were all valve guide problems. As far as I know, all their newer stuff is just fine. Do you know if those are the first version of the twisted wedge heads?
Old Aug 12, 2009 | 11:38 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New heads
Well i dont remember the number of the heads but i can look into that.
The first year ended with that I had to change the crankshaft bearings in the engine and the new crankshaft was completely destroyed by only 1000 km driving because two valve guides were GAPE.
I'm running now with a different shock rods and lachcaps on some, do not want it that way.
I have drilled four bounce, two new valves, four new valve guides, new springs for this year.
sök
Old Aug 13, 2009 | 10:37 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: New heads
Don't mean to step on anyone's toes (or ego), but I wouldn't say 195cc for sure. 195s would work, but I'd just get 180cc RHS heads....Cheaper than Darts and just as good or better. Even 383s with 180s can make over 500 hp (at sea level) with the right combo of parts.
Old Aug 13, 2009 | 03:54 PM
Engine: L98 494hp
Re: New heads
Yes but the volume is better using a 195cc heads......the 180cc have a lot better velocity than the other, Yes 180cc would work great....but I was thinking that 195cc in case future plans include a 383 or something more radicall....I don't think either head will be that far off from one another.....I would personally chose the 195cc...but I agree the 180cc heads will work great....I use 200cc personally...The only thing I don't agree with you on is 180cc on a 383....I would def. not go that route...no questions asked....but everyone has their own ideas and opinions....
Old Aug 13, 2009 | 04:01 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: New heads
Ok thanks
195's
Old Aug 13, 2009 | 04:04 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: New heads
That's what's so cool about all this stuff...I respect other's opinions, and they respect mine. Good stuff!
Old Aug 13, 2009 | 04:37 PM
Engine: L98 494hp
Re: New heads
I agree....sometimes there is no respect though....but it's nice when you have it!!! Thanks..
Also while either one would work, I would personally go with 195cc.
Also, just to throw my two cents in there on something else...your losing power with you k&n open air element.....someone else (I think 1bad91z) did a dyno compare on stock airbox and open element....made more power with stock airbox due to sucking in of engine heat......I make an aftermarket custom air box that will flow quite a bit more.
Old Aug 13, 2009 | 06:48 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: New heads
Ahhh...OK, you were talking to the sweden dude about the K & N air filters....I don't have an IROC at all, YET, so I don't have any kind of elements to worry about. So, the dude will be happy with either 180s or 195s...I guess that's a good conclusion for him. And.....Right, sometimes there is no respect. It's hard to read TONE here in the forums sometimes. I'm not an arrogant or know it all kinda guy, and I'm sure not many are, but sometimes people get offended and think someone is trying to be a know it all. If someone knows something that will help me, then I am thankful. Usually, the best learning is from people and hands on experience or BOTH.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
