knock sensor problem
Old Aug 14, 2009 | 10:01 PM
bd_slim's Avatar
Car: 89 iroc vert-91z-28
Engine: 305 tpi-305 tpi
Transmission: 700r-4-700r-4
Axle/Gears: 3.23 posi-3.73 posi
i have a 91z 305tpi. as soon as i start my car, the ses light comes on and stays on. pulled code 43. its been like this since i got it. i recently tested the voltage going to knock sensor, and it was good. then i checked the ohms of the knock sensor and get nothing. it runs alright with a slight miss on occasion while cruising and under wot it seems like its lacking some power. it runs pretty good, i just think that its not all there. my question is how much power will a bad knock sensor rob me of? i plan on replacing the sensor when i install my headers later on, but if it'll make a big difference in how my car runs i'll change it now. i have a hypertech chip that was in it when i bought it, cat delete with flowmaster cat back, shift kit, 3.73 posi, k&n, and i can't even chirp the tires from a dead stop. like i said, i bought the car this way, so i can't compare how it ran before the code 43. thanks
Old Aug 20, 2009 | 04:56 PM
bd_slim's Avatar
Re: knock sensor problem
no info on a bad knock sensor?
Old Aug 20, 2009 | 07:13 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
it will rob you of a lot of power because the timing isn't advancing like it sould, i would replace that knock sensor
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
